Metal cutting saw
   / Metal cutting saw #1
fcamillieri
Chester, NH
CK20HST
Has anyone tried this saw from Dualsaw.com?
Looks pretty impressive for cutting just about anything short of cement.
I'm thinking it would be perfect for cutting up plates of steel if it could handle 1/2" thick material.
Frank
   / Metal cutting saw #2
I watched the video clip on the web site. Looks pretty good. I wonder how long the blades would last cutting steel.
   / Metal cutting saw #3
in my opinion. wount cut 1/2 in steel plate maby good for thin stuff, also blades wount last saw runs to fast for steel also carbide teeth mite chip.
   / Metal cutting saw #4
My father just bought one of those things. I am in construction and I just used it while installing a screw down metal roof and I gotta have one. It worked great and I cut over 100 feet of 25 guage roofing and it didn't seam to dull a bit. Awsome control and it contained the metal chips extreamly well. I was very impressed.
   / Metal cutting saw #5
Own one like it will cut 1/2 plate.But not very good blades dont last cost
about $50.00.Save your mony. Framer
   / Metal cutting saw #6
I donno, it's one of those "Billy Mays" things, si I'd agree with framer, pass.
I don't know if you are looking for the ultimate in portability or not, but a plain old metal cutting chopsaw should fit the bill. This one is similar to the Hitachi I have. - Harbor Freight Tools - Quality Tools at the Lowest Prices
If this would work for you, make sure you use internally reinforced blades, such as United Abrasives 14 X3/32 X 1 Metal Iron Worker blades, part # 24051, they work great for me.
   / Metal cutting saw #7
I have this chop saw, and it cuts extremely well. The saw cut looks like it is polished. Very little sparks. The rpm of the metal cutting is slower than the reg chop saw. There are different blades for cutting steel, aluminum, etc. It will cut 6 in steel. If you have never used one, you just don't know.
Amps 15.0 AC/DC Amps No Load Speed 1,300 rpm Spindle Lock Yes Quick Lock Vise Yes Wheel Arbor 1" Wheel Diameter 14 " Max Capacity (Round) 5-3/16 " Max Capacity (Rectangular) 6-1/2" x 4-1/2 " Tool Length 21 " Tool Weight 47.0 lbs Horsepower 4.0 HP Includes: 14" carbide tipped blade wrench vertical clamp
DeWalt DW872 Heavy-Duty 14in. (355mm) Multi-Cutter Saw - Toolfetch.com
http://mtechsales.com/products/CircularChopSaws/
   / Metal cutting saw #8
J J how long do the blades last on that saw cutting say angle iron. $50-$80 for blades i would hope they would last a while. is it louder than the disk style that dewalt makes (thats what i have) Thanks
   / Metal cutting saw #9
I have cut a bunch of steel, all shapes and sizes, and it is still sharp. The blade life will depend on what you are cutting. Stainless steel needs a different blade. The teeth angles and rake are different. I lost one tooth by lowering the saw to fast. I have seen 14 in blades as low as $30.
You should be able to cut angle iron all day.
http://www.toolsofthetrade.net/industry-news.asp?sectionID=1492&articleID=501357
   / Metal cutting saw #10
Thanks j j . . .i think this is going to go on my christmas list.
2018 Ford F-350 (A55973)
2018 Ford F-350...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
case 370 glass door never installed (A56436)
case 370 glass...
