5w40 Syn - even if warranty calls for 10w30??
   / 5w40 Syn - even if warranty calls for 10w30?? #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
Planning our 50 hour service on the 1635. MF calls for 10w30, but I am not going to run dino past the 50 hour mark. Cannot locate 10w30 syn that is CJ4 compliant, since the tractor is Tier IV interim, I want an oil that meets or exceeds specs.
MY question, will running 5w40 syn harm the tractor? Even during the hot summer months?
Looking at Amsoil 5w40.
   / 5w40 Syn - even if warranty calls for 10w30?? #2
There's plenty of synthetic 5w30. I use Mobil 1 0w30.
By specifying 10w30, they're saying 15w30 or 15w40 or 0w20 isn't allowed, but 5w30 or 0w30 is and are better.
I worked in the lube oil industry for 31 years.
Is it CJ4 rated??
   / 5w40 Syn - even if warranty calls for 10w30?? #4
Why so keen on synthetic oil?
Well, first off, Cold starting abilities, second of all, it is not cheap, runs cleaner, less deposits, tractor meets Tier IV, and ULSD is a killer on these things. Plan on keeping it a long time, and also want to take care of it. Have not run Dino in years, in anything, and DO NOT plan on EVER going back.
   / 5w40 Syn - even if warranty calls for 10w30?? #6
How would they know??? Once in a small diesel engine, the oil looks the same coming out, black and sooty. I can say I went with Mobil diesel synthetic in my diesel Gator (854 cc Yanmar) and in my little 2320 tractor (TNV series--similar Tier to yours) and it REALLY helped cold starting and fuel efficiency. I have been most well-pleased. I would do this in a heartbeat.
John M
   / 5w40 Syn - even if warranty calls for 10w30?? #7
A long time ago GM used to warn specifically AGAINST the use of wide viscosity range oils in diesel engines.
Something about viscosity range extender "residue" accumulating under bottom rings and leading to ring failure - as I said, long time ago so I'm not remembering the details at all clearly.
It might be worth a search though.
MF (AGCO) does not have a problem with it, if they had their own synthetic oils, (like JD does.) I would buy from them.
   / 5w40 Syn - even if warranty calls for 10w30?? #9
Call your local oil distributor. Amazing what they have or can order. My uncle is one Shell. Many things are regional or special order. I find the prices right on line with Walmart or Auto Zone if not better... I even get 55 gallon drums of Windshield Washer Fluid from them to load tires on tractors for about 1/2 the price of gallon jugs.
Chris
   / 5w40 Syn - even if warranty calls for 10w30?? #10
I'm not even close to buying that. OEM's recommend specific viscosity oils; others are excluded by omission.
I work in the Ag equipment industry, but that doesn't make me a mechanical engineer.
   / 5w40 Syn - even if warranty calls for 10w30?? #11
If 5w-40 is what you want for cold winter starts and summer use in heat, and you want sythetic, consider Rotella T 5w-40. It's what I intend to use.
Availability. TSC, WalMart with Wally's price, its pretty hard to beat.
   / 5w40 Syn - even if warranty calls for 10w30?? #12
40w oil is not called for in his warranty. 10w30, 5w30 or 0w30 are all allowed. The 5w30 and 0w30 were all manufactured after his warranty was written up.
5w30 is what the dealer sells for my new VW TDI, for instance.
   / 5w40 Syn - even if warranty calls for 10w30?? #13
Amsoil is great stuff, and you will not go wrong using it. I have been using it since 1983, and do not use anything else. End of story. All my vehicle are synthetic engine, trans, and diffs. Tractors are engine only as I have to many hydraulic leaks to use synthetic there. One big difference with syns vers petroleums is that there is not an additive package in the syns. They are engineered as the weight and oil type that they are. Amsoil was one of the original designers and makers of syns and they were designed for the cold WI winters. Amsoil did not get on the synthetic band wagon when they realized they were losing sales to other oils. Amsoil was one of the starters of the synthetic oil revolution. The Shell is okay stuff, but for the couple of bucks more, get the amsiol. Besides, the last time I bought the shell for a 301A JD that burns oil, it was almost the same as the Amsoil. You can get a private party dealership for a few bucks a year and buy at wholesale levels. Shipping is where Amsoil will get you. If a warehouse is close go pick it up and save. I get mine from the Lancaster PA location when I have to go up there to sell hay at the auction. On 5 gallons, usually saves $20 on shipping. The Amsoil will stop the wear inside or engine, so you have to go through the normal break in period with petroleums. Do not know the recomendation for your tractor, but for cars and pickups it is usually 5K before you switch. Call tech at Amsoil, and they will put you on the right track. Bottom line, your engine will last forever on Amsoil.
GM warned against using synthetics until they got caught sending their vehicles to EPA for mileage testing with synthetics in them. GM knew you would get better mileage, and they would not sell anywhere near as many motors and parts if people found synthetics. Go GM!
   / 5w40 Syn - even if warranty calls for 10w30?? #14
The recommended oils are based on temperature.
NH states 30W or 15W40 or 10W30 or 5W30.
The one thing I've noted is that 95% of the diesel CJ-4 that you can find is the 15W40 ....... the others are difficult to locate.
   / 5w40 Syn - even if warranty calls for 10w30?? #15
I did a casual "reminder search" last night.
Whether or not MF (AGCO) knows, doesn't know, or chooses to not comment may be beside the point - or may have motive.
The point is that polymers are used as viscosity range extenders in mineral AND synthetic oils, they "burn" under lower rings and it is the burned deposits that are the problem.
The wider the range the more polymers, the more polymers the worse the condition.
They loose their range very quickly too, as the polymers burn off, so the wide range isn't there for very long anyway.
I guess I should say "POTENTIAL PROBLEM", since any number of folk will chime in with their anecdotal "I've used xWy0 on n vehicle engines for decades", etc. believing THAT to provide statistically valid guidance (-:
Besides all that do any of us really NEED such wide viscosity range oils ?
(Assuming that they keep that range... which they don't)
Are we living in conditions that require or even benefit from 5W or 0W for cold starting AND 40 or 50 for high temperatures ?
or are we putting 100 or more hours on a year and changing oil twice a year anyway ?
NO ONE makes a 10w30 or 5w30 CJ4 synthetic oil, and I am NOT going to run Dino. Not running 0w20, that is below what is called for.
That is the dilemma.
   / 5w40 Syn - even if warranty calls for 10w30?? #17
My current machine only takes 3.5 qts of oil and I just bought a case of PureOne filters .............. So I will be changing it about every 25 hours ..... to me it doesn't much matter if it's dino or synth.
   / 5w40 Syn - even if warranty calls for 10w30?? #18
That is right about wide range multi when talking Dino oils because they need more extender additive to get the range. Syns are OK because they naturally change viscosity less as T rises. They need much less additive to get a broad Multi visc range. [ie: They have a high viscosity index]
larry
   / 5w40 Syn - even if warranty calls for 10w30?? #19
I would go with 5w40 or 0w40 then. Shame - at your latitude the 30's would be the best ticket. Not a safety/damage issue, but a microscopic decrease in efficiency moving the heavier oil thru the hydrodynamic bearing shear zones.
larry
Well from as cold as (or colder) -50c(-58f) in the winter to (or hotter) +40c(104F) the benefits of syn outweigh the benefits of dino. Also, this is our main tractor now, so 150 hours will probably be the minimum we hit.
1993 Military Potable Water Tank Trailer (A59228)
1993 Military...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
2018 JOHN DEERE 35G EXCAVATOR (A60429)
2018 JOHN DEERE...
207279 (A52708)
207279 (A52708)
