BX 3PH float position?
   / BX 3PH float position?
You can adjust the link found inboard of the right rear tire to not spring back to center from the "down" position. That should give you true float since the valve will remain open.
The link is easy to find by tipping up the seat and looking about 4 inches from the right tire toward the transmission. There is a spring on both ends of the linkage where it goes through a swivel. The front spring is the one that controls the down lever if I remember correctly. Just operate the 3 PH lever and it will become obvious which compresses for the "up" and the one for the "down" stroke. Have the engine running and you will see how the return works.
There is a cotter pin in the front spring that can be removed for completely disabling the "down" return thus leaving the valve open.
I think my BX may use a different system. Here's how my 3PH control lever works.
1. Above the right-side fender.
2. Under the right-side fender.
3. Control lever linkage connection at the transmission. I see no springs anywhere. Nothing is attached to the arm until it connects to the transmission.
4. Here are some metal tabs that serve no apparent purpose. They sit just below the fender. It looks like I could swap the two tabs and pivot the front out a little. The play in the 3PH control lever (center in this shot) would be enough that I could hook it on the front tab and lock it forward. Then, with a nudge away from the seat, it would release.
5. For good measure, here's the whole rig sporting its brand-spankin' new chains.
   / BX 3PH float position? #22
Dave if you have something similar to the part in the red circle, that's the adjustable linkage that has been referenced, that kicks the lift lever back to neutral, if you don't have that part, the newer models are different than my 2001.
   / BX 3PH float position? #23
The newer 50 and 60 series BXs (ie: BX2350, 2360, BX24, 25) have a different 3 pt than the earlier versions that Milkman illustrated. There is no linkage on the later versions.
The metal tabs mentioned above are components of the Quarter Inching system. The tabs limit the travel of the lever allowing a very small movement of the hitch. Pull the lever sideways in between the tabs, move it forward or backward to the stop and release. The hitch will move approximately 1/4".
milkman - I couldn't get a very wide shot because the blade was still attached. I didn't see anything like that. Thanks for the picture though.
Yes.. I turned that locking nut with a channel lock.
I always wondered what the "Quarter Inching system" was.
Doesn't that depend on the setting of the release valve? Anyway, I don't think I'm much interested in that feature. Those tabs are going to be re-purposed.
   / BX 3PH float position? #26
OK, now that the model is known my posts are moot.
I case anyone has a BX2200 with the same issue, here is a picture from above with the seat tilted forward. Gas tank on the right, 3PH arm just above the springs in the photo.
The front-most spring is the down return, the rear-most is the up return.
   / BX 3PH float position? #27
I have used chains instead of lift arms when I wanted a 3pt implement to "float". Mostly on my landscape rake to move piles of debris across my uneven field.
   / BX 3PH float position? #28
Agree with just2quick - try using a chain in place of your top link with some slack in it. As your back wheels go over a hump, the blade should rotate on the lower link pins and stay in contact with the ground as long as there's enough slack in the top link chain. This will mean you can't raise the blade as high as with a normal top link, but it should give you the downward float you're looking for. If you want it to float side to side, replace one of your vertical side links with chain.
   / BX 3PH float position? #29
That's a good idea, I remember one of the guys at work mentioning that his Dad used to use chain for a top link on their bush cutter to help it follow terrain better. Land Pride tells you to set the top link length so there is a slight sag in the linkage when the mower is sitting level. The more sag you have, the less lift height you'll get when transporting, but you can shorten the chain before you do that.
Chilly
   / BX 3PH float position? #30
I believe the OP was using a blade. Using a chain for a top link will allow the blade to just fall over forward. When pulling the blade, the top link is in compression. When lifting as in raising the mower, the toplink is in tension so it works.
I think Just 2 Quick was referring to substituting chains for the connecting rods from the upper lift arms to the lower lift arms.
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
ALLISON TRANSMISSION (A55745)
ALLISON...
3Pt Aerway (A59814)
3Pt Aerway (A59814)
2021 Deere 331G (A53317)
2021 Deere 331G...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
Westendorf 400 bu Gravity Wagon (A59814)
Westendorf 400 bu...
