Mowing 54 or 60 inch mmm
   / 54 or 60 inch mmm #1
Chugbug
Central Ohio
BX25
Looking a buying a mower deck for my BX25. I enjoy my time outside on my toy (oooppps) tractor so cutting time is not an issue. I have an 8 X 5 trailer to load the tractor only on, how much difference is the 54 inch cut from the 60. I'm thinking the 54 so I can get in on the trailer, not a lot of trees to cut around. Thoughts???
   / 54 or 60 inch mmm #3
When going from 54" cut on my JD to a 60" on my Kubota, I was somewhat apprehensive, but I wouldn't even think of getting another 54". Mowing time is only one consideration for me. I like being able to trim better under obstacles, in ditches and along banks. I have a 5x8 trailer, but wouldn't haul anything as heavy as a Kubota, so I bought a bigger one.
   / 54 or 60 inch mmm #4
Get the largest deck that your property/situation allows.
   / 54 or 60 inch mmm #5
Get the 60" deck, like someone else said, the left side stick out a little further and lets you get under things better.
   / 54 or 60 inch mmm #6
I love my 60" MMM.
Just because the deck CUTS 54", don't automatically assume it will fit on a 5' wide trailer. There are a few inches on the left side for the deck itself and on the right side, the deck shroud flares into the chute, adding even more width. You can bungee the chute up, but even it has 'ears' that stick out.
If you measure the deck tip-to-tip, I have a beer that says it won't fit on a 5' wide landscape trailer.
I'd buy to the property...not to the trailer. Another way to put it is that the deck you're buying costs at least twice as much as your trailer...my 5' x 10' trailer cost me ~$750 in 2003...you can get a big single axle or a small double axle for much less than $2,000. Try not to let the tail wag the dog.
   / 54 or 60 inch mmm #7
Sell the trailer you have. You will more than likely get what you paid for it. There is always someone looking to purchase a 5x8 trailer. Then go with the 60" deck. I have a lawn tractor now with a 54" deck and it is not as big as I thought it would be.
on a side note. I just looked at a the 72" deck at the dealership and that thing looked really big.
   / 54 or 60 inch mmm #8
That's pretty good advice. I bought the 54" deck with my 2230 specifically so it would fit my 5'x10' trailer, which it does, but it turns out we have not trailered it with the deck mounted in over 5 years. It's always bare tractor or with FEL + some 3pt implement. The 54" works fine for our uses, but we could have gone with the 60" just as easily. Of course, others may have different needs.
   / 54 or 60 inch mmm #9
...72" deck...
For a BX?
...have not trailered it with the deck mounted in over 5 years.
The only time I trailered mine with the mower deck was for service. I did it on my 5' x 10' trailer ONCE.
Actually, I didn't do it...I loaded my deck, took it to the dealership, used one of their tractors to remove it, drove to the house, loaded my tractor and took IT to the dealership...reverse procedure to come home. Pain in the rear.
The prospect of future $300 pickup/delivery charges, inconvenience, and constantly overloading my little trailer prompted me to purchase my big trailer. I LOOOOOOOVE my big trailer.
   / 54 or 60 inch mmm #10
Looking at buying a mower deck for my BX25. I enjoy my time outside on my toy (oooppps)
1*So cutting time is not an issue.
2* I have an 8 X 5 trailer to load the tractor only on, how much difference is the 54 inch cut from the 60.
3*I'm thinking the 54 so I can get in on the trailer,
4*not a lot of trees to cut around. Thoughts???
1*The volume of trimming left to do after mowing is.
2*Is this a 1 or 2 axel?
Does it have brakes all axels?
What do you tow it with?
3*I'd get a bigger trailer .
I'm looking for 1 18 foot long at least 7 feet wide for my bx23.
4*I's not the trees that matter it's the ability to trim along ditches and banks .
The narrower 54'' mower forces you keep farther away thus leaving a larger area to trim with a back breakin string trimmer.
The 54 '' mower causes scraping / scratching damages to the tractor or you have stay so far away from objects which results in more trimming .
1*I wouldn't even think of getting another 54".
2*Mowing time is only one consideration for me. I like being able to trim better under obstacles, in ditches and along banks.
3* I have a 5x8 trailer, but wouldn't haul anything as heavy as a Kubota, so I bought a bigger one.
1*Rite on.
2*Yeah .
3*Way to small.
1*Get the largest deck that your property/situation allows.
1*Correct
1*Get the 60" deck, like someone else said, the left side stick out a little further and lets you get under things better.
1*Even a 60'' leaves more to trim along ditches and banks than I want.
207271 (A52708)
207271 (A52708)
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
