92 3500 or 90 350
   / 92 3500 or 90 350 #111
I agree the 45' is too long. I had a 25' that was just right that had 25,000# gvwr. It was sitting on tandem duals.
Like the others said weigh your truck first then do the math. Say your truck has a 24,000# max gcvwr and the truck weighs 9,000 then you 15,000# to play with.
Same thing with a trailer. Say you get a 25,000# trailer like I had. It weighed 6,000# so it had a usable load of 19,000#.
Chris
   / 92 3500 or 90 350
so where do find my gcvwr
as for the truck weight, I have that somewhere in my paperwork.
thanks
so.. in essence.. still look for that 20k trailer.. just one more in the 29-33' range.. :) otherwise it looks like 14k is the next step.. IE.. 2 7k axles.. etc.
soundguy
   / 92 3500 or 90 350
may have found some good info:
while looking thru my owners manual I found a trailer towing table.
it lists up to the f550.. for the 450 it lists a manual and auto tranny.. but only lists the 5.4l and 6.8l, not the 7.3
still.. the 6.8l 450 w/ 4.88 rear has a gcwr of 24000#
trailer weight rating for a class iv hitch is 10k# with a listing for 5th wheel as gcwr-gvw
that looks good.. I thought I was stuck with a 17700 rating.
my thinking correct here?
comments?
soundguy
   / 92 3500 or 90 350 #114
comments?
soundguy
SG:
Check out the 1999 F450 Diesel Supplement here
http://www.motorcraftservice.com/vd...new&MARKET_LANG=US-EN&YEAR=1999&VEHICLE=F-450
http://www.motorcraftservice.com/pubs/content/~WOXF23/~MUS~LEN/30/9973l731e.pdf
   / 92 3500 or 90 350 #115
17700 is the maximum load you can tow, trailer and cargo. 24000 is the maximum that the truck, trailer and load can weigh. You're still in good shape. My recommendation would be to buy a 30' dual wheel tandem with a dovetail and folding ramps. It's a good match for your truck and it'll carry any load you care to put on it.
   / 92 3500 or 90 350
ok.. I got ya.. 24k for the whole enchalade.. me, the old lady, the truck, the trailer and the tractor.. with it divided so that no more than 17700 can be aft of the truck following it down the road.. meaning the other 6300 would have to be truck and cargo.. which since it weighs more than that, the 17700 number will be reduced by the actual truck total weight.
got it now.
I'm going to look at another 30' tandem on monday and a 24' tandem.
soundguy
   / 92 3500 or 90 350
flusher none of those links worked for me.. said 'forbiden'.
perhaps I don't have permission to be on those sites like you might?
are they pdfs you can attach here?
thanks guys! ""everybody"
soundguy
   / 92 3500 or 90 350 #118
got it now.
soundguy
Sounds like all the mumbo-jumbo is finally starting to sink in and make sense for you. Once you get your mind around it...it's really pretty simple.
   / 92 3500 or 90 350
only because you guys are making it simple for me. :)
really apprecaite the schoolin on haulin!
soundguy
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2006 Volvo VNL (A52748)
2006 Volvo VNL...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2017 INTERNATIONAL PRO STAR (A52472)
2017 INTERNATIONAL...
