post hole digger
/ post hole digger #1
casolorz
Wichita, KS
Kubota BX1860
I found someone selling a John Deere Model 31a post hole digger. Does anyone know if that will work with my small kubota bx1860?
Thank you,
--Carlos
/ post hole digger #2
My guess is no due to the "limited" 3PH of your machine...you probably won't be able to lift it high enough for the auger to clear the ground.
/ post hole digger
Do you know the specs of that post hole digger? I haven't found them.
/ post hole digger #4
I do not, sorry. But as far as I know its is a standard duty PHD for CAT1 hitches. Woods markets the PHD25 for SCUT tractors with limited CAT1 hitches.
/ post hole digger
I have found another post hole digger on craigslist and this is what the owner said about the dimensions:
"The over all length from the gear box to where it attaches to the tractor is about 6', the distance between the two pins where the tractor arms would attach is about 2' 6". The p.t.o. shaft is adjustable from about 4' on out to whatever length is needed."
Does anyone know if that would work with my bx1860?
Thanks,
--Carlos
/ post hole digger #6
Thanks,
--Carlos
Our L7200jr post hole digger is made specifically for your subcompact Kubota. I made a video about what the difference is between the two and explain why only certain post hole diggers will work with a subcompact tractor. I also have a video on assembly and shipping method as well as good pictures.
Hope this helps . . .
/ post hole digger
That was very helpful. Do you know what the max diameter I can get for my tractor?
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
