Ordered a WR Long valve and OBG2 for my B3200
   / Ordered a WR Long valve and OBG2 for my B3200 #1
JTPass
New Hampshire
Kubota B3200
I finally decided to order the Long OBG2 48" grapple with the Long third function valve. I am going to have a local Kubota/Long dealer do the install. I have a Kubota quick attach which will work with the Long grapple as long as it is set up with the LA504 pin out, which I asked for. I can't wait to put it to the test.
One concern I have is the brush guard, if that's what you can call it, on the B3200. It will will not do much to stop brush and branches. has anyone fitted the brush guard with expanded metal or any such material to really let it act as a brush guard? How did you attach it? Does it affect air flow for cooling?
Any information will be appreciated.
Jim from NH
   / Ordered a WR Long valve and OBG2 for my B3200 #2
Jim from NH
I have an RBG-60 on my L5030 and I love it. I had a lot of brush and logs I needed to move when I purchased it, so as soon as I received it, I installed it and the Long valve kit. I debated whether to put expanded metal in place before I used it or "move some brush first." A year later I still intend to add some expanded metal, but just have not done so yet. I had planned to bolt it on with u-bolts as a temporary measure until I could make up a frame with hooks on top and brackets to bolt in at the bottom.
I do not see a a problem with cooling, and yes, I still need to add the extra protection. I have really not had any problems yet with anything getting beyond the existing brush guard, but I am likely pushing my luck, so this is still on my project list.
To further protect the hoses, I covered them with split flex conduit that I got at Tractor Supply. I also use a small bungey cord to keep the hose slack out of the grapple. One of my neighbors has a grapple that I looked at before I bought mine. He had not added the above to his but as we looked at his equipment, we both agreed this would be helpful. I picked up the items and put them on as part of the installation.
You may already be aware, but as a heads up, when you get ready to remove the grapple from the tractor, shut the engine down, turn the key back to power the valve, then take the pressure off the lines by pressing the open/close button several times in each direction before you disconnect the couplings. Even then, if you remove it in the sun, you will probably have to relieve the pressure in the grapple lines again to get the couplings to connect. I cover the male coupling with a rag and push the end against the grapple frame. I will let the safety police tell you about high pressure hydraulic fluid.
I hope you find your grapple as useful as I have mine.
Kubietwo
   / Ordered a WR Long valve and OBG2 for my B3200 #3
I have an WR Long grapple - RBG2-60 with a Fasse controller on an L4310. I don't have a brush guard either and having used the grapple 2 years - only got branches caught up in the hoses.
Brush guard would be good insurance though.
Thanks for the responses. I will probably put the brush guard on my "to-do" list also. I just hope it doesn't end up on my "wish-I-had-done" list.
I should have the valve installed and grapple within a few weeks. I will let you know how it turns out...with some pictures also.
   / Ordered a WR Long valve and OBG2 for my B3200 #5
Good choice, I'm pleased with my WR Long OBG2-48 on my L4240 and it should be a good match for your B3200. Here's some pictures to look at while you wait for delivery & to maybe give you some ideas for a brush guard design. I haven't added one to mine yet either but can see why it would be a good idea.
CB...Nice set-up you have, thanks for the pictures. They have me anxious for mine to be done. I dropped it off on Sat and should have it back this coming weekend.
   / Ordered a WR Long valve and OBG2 for my B3200 #7
Jim...glad to see you joining the grapple crowd. I think you will find it very helpful around your place. In regards to the brush guard, I also had this as a concern, and also on my "to do" list.......still havn't gotten their yet......
I really havn't had an issue needing the brush guard. As long as you keep an eye out while grabbing the piles brush or debris, you should be fine.
JUST make sure you have enough ballast!! That can get you in trouble REAL fast!!!!
Mike
   / Ordered a WR Long valve and OBG2 for my B3200 #8
Add the guard ASAP, if not this can happen: I found a dent on the front panel
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
MULCHER (A58214)
MULCHER (A58214)
