Got a New Generator
/ Got a New Generator #1
techman
N.E. PA
BX22
Upgraded my genset at home for a new Kubota powered 9.8 KW. Had a Duetz aircooled 8 KW before. The Kubota is really nice. 1800 RPM and water cooled and it is nice and quiet. Added bonus is lower consumption, and auto start. I worked 6 days on and off getting it installed, fuel set up, exhaust run and wiring done. I have a manual transfer, so it is a switch to start, but from in the house.
Anyone interested in an 8KW Deutz diesel genset with less than 25 hours, sens me a PM.
Paul
/ Got a New Generator #2
Just curious why you updated a virtually brand new generator?
Just wanted to get a quieter, more efficient and easier for the wife to start. I always wanted a water cooled, 1800 RPM unit, so when I found the extra money I went for it. Several types on the market but I opted for the Kubota powered. Hopefully common filters and knowledge with the BX.
paul
/ Got a New Generator #4
I acquired what looks to be an identical unit 2nd had over 10 years ago and it is still going strong. I am interested in the details of your fuel tank system and info on where I might find same. What was the cost of the genset?
/ Got a New Generator #5
Nice setup! I have a Kubota GL6500 that I bought several years ago. Used to have a Honda 6500 gas and never had enough gas around when I needed it. Since I bought the diesel I think I have needed it twice! But you never know when the next hurricane or ice storm will come around. Great piece of mind.
I bought the tank some years ago from BassPro. It's an 8 gallon marine unit. I had to add a return (common for diesel engines). I machined a threaded collar and brazed it to a length of rigid brass hobby tubing. Then I soldered a barbed hose fitting on top and fished it into the tank and clamped it fast with a nut. At the time I paid under $20 for the tank. I also have 50 gallons in a plastic barrel on the other side of the shed for the tractor and genset.
The new gen was around $5K all inclusive and shipped.
Paul
/ Got a New Generator #7
Nice looking unit!!! Is that a sucker or a pusher fan? I did not see any ducting for the fan, so how do you keep the shed from getting hot and overheating the engine? Philip.
Fan is a pusher. Summer just open the shed door when running. Winter crack door and heat shed (along with tractor).
Paul
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A64557)
2013 29ft. Larson...
