Got a New Generator
/ Got a New Generator #1
techman
N.E. PA
BX22
Upgraded my genset at home for a new Kubota powered 9.8 KW. Had a Duetz aircooled 8 KW before. The Kubota is really nice. 1800 RPM and water cooled and it is nice and quiet. Added bonus is lower consumption, and auto start. I worked 6 days on and off getting it installed, fuel set up, exhaust run and wiring done. I have a manual transfer, so it is a switch to start, but from in the house.
Anyone interested in an 8KW Deutz diesel genset with less than 25 hours, sens me a PM.
Paul
/ Got a New Generator #2
Just curious why you updated a virtually brand new generator?
Just wanted to get a quieter, more efficient and easier for the wife to start. I always wanted a water cooled, 1800 RPM unit, so when I found the extra money I went for it. Several types on the market but I opted for the Kubota powered. Hopefully common filters and knowledge with the BX.
paul
/ Got a New Generator #4
I acquired what looks to be an identical unit 2nd had over 10 years ago and it is still going strong. I am interested in the details of your fuel tank system and info on where I might find same. What was the cost of the genset?
/ Got a New Generator #5
Nice setup! I have a Kubota GL6500 that I bought several years ago. Used to have a Honda 6500 gas and never had enough gas around when I needed it. Since I bought the diesel I think I have needed it twice! But you never know when the next hurricane or ice storm will come around. Great piece of mind.
I bought the tank some years ago from BassPro. It's an 8 gallon marine unit. I had to add a return (common for diesel engines). I machined a threaded collar and brazed it to a length of rigid brass hobby tubing. Then I soldered a barbed hose fitting on top and fished it into the tank and clamped it fast with a nut. At the time I paid under $20 for the tank. I also have 50 gallons in a plastic barrel on the other side of the shed for the tractor and genset.
The new gen was around $5K all inclusive and shipped.
Paul
/ Got a New Generator #7
Nice looking unit!!! Is that a sucker or a pusher fan? I did not see any ducting for the fan, so how do you keep the shed from getting hot and overheating the engine? Philip.
Fan is a pusher. Summer just open the shed door when running. Winter crack door and heat shed (along with tractor).
Paul
New/Unused Wolverine 84in Quick Attach Rock Bucket (A65583)
New/Unused...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2017 Ford Explorer 4x4 (A62679)
2017 Ford Explorer...
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
International 574 Loader Tractor (A66285)
International 574...
