I also posted this in the general repair sub-forum.
I am looking for any recommendations or counsel regarding the installation of a block heater on my Kubota L5030.
The one page of instructions that came with the kit says that I must remove the hydraulic pump to install the block heater.
It also requires driving a steel sleeve into the block using "Locktite" (but does not specify what type, which makes me wonder if they mean something like Permatex sealant). The steel sleeve has a smooth outside diameter (where it looks like a friction/interference fit into the block), and the inside diameter is threaded to receive the actual heater element (which requires "teflon tape" type of thread seal).
The final caveat in the instructions is (after driving the sleeve in with a mallet) to ensure that you have not punctured the cylinder sleeve of the block.
That warning set my brain on fire.
Have any of you done this job?
