The cost of Hydraulic hose's ... WOW!!
   / The cost of Hydraulic hose's ... WOW!! #11
Well Kenny I don't think I could have made my own. I was shopping the 3/8 at TSC and ya know when a couple hose's added together run 50 bucks x 2 or 100 and then the misc adds up and in your mind your thinking the $150 or so ... never dawned on me that when I asked for the 3/8 and all the stuff... well I quess it was sticker shock!!
But darn they are nice and I am proud of them!!
Sure you can: Re-Usable Hydraulic Hose Fitting Tutorial - TractorByNet.com
   / The cost of Hydraulic hose's ... WOW!! #12
I really lucked out when I had the hydraulics hooked up for my grapple. The local Cenex station does custom hoses, so I went there expecting to drop off the tractor and pick it up when it's done. Bill, the hose guy, told me to stick around and give him a hand. I obliged, and when everything was done, he only charged me for the parts. I was a little shocked (pleasantly, of course) by the omission of the labor, when Bill said, "You did all the work."
Gotta love small towns!
Joe
   / The cost of Hydraulic hose's ... WOW!! #13
I provide the hoses n fittings and take them to the cannery and have one of the mechanics crimp them for me. For a few crab, get all my hoses made up for me.
Rick:thumbsup:
Yep ... it appears as though the parts from them would have been $154 plus S&H ... and per Kennyd's thread it appears to be something I could have made.
Thank you ....
   / The cost of Hydraulic hose's ... WOW!! #16
I get all my stuff done at Discount Hydraulic Hose.com
So much cheaper. I need 2 18' hoses last year for my snow plow and locally they wanted $300. I got it for just over $125 from them. I just got a order yesterday with special Komatsu ends made for $120 for 4 hoses. My local guy was $220.
You just order what you need to make the hoses then they charge a $10 per hose assembly fee. Example: 12' of 3/8" hose and 4 fittings Part #58320985, and 4 fittings part #7gt777745
During the checkout process there is a section where you can put your specs. Something like "Please make 4 hoses each 3' long using one fitting 58420885 on one end and one fitting 7gt777745 on the other end. If you have any questions please call me at the phone number in my profile".
That easy.
Chris
   / The cost of Hydraulic hose's ... WOW!! #17
The is a lot of diversity in the hose and fitting market, from non-named China imported hose to brand name hose and fittings. Although the truth is almost all the hose is made in Asia there is a noticeable quality difference in brands still, along with price differences; make sure you are comparing the same items.
The cost of parts of what you described is probably about $100 (Parker brand) which doesn't include the quick disconnects, depending on the style can range greatly. We tend to use a lot of flat faced which cost us nearly $60/set but many types are less than $20/set.
Reusuable fittings are an option for small quantities of hose that need to be made up on the spot or run through tight areas and finished off on the machine. Keep in mind they tend to cost nearly twice as much as one piece crimp fittings and on short hoses are more expensive than crimps.
   / The cost of Hydraulic hose's ... WOW!! #18
I guess I should say that all the hoses I have received from the company I listed above are from Eaton. I have place 3 orders since 2006 and all have saved me quite a bit of money and been top quality.
Chris
   / The cost of Hydraulic hose's ... WOW!! #19
Thank you sir ... I just keep learning everday. Now I am going to that link to see if I am going to cry like a baby ...
Thank you ....
Sorry to make you cry:laughing:
   / The cost of Hydraulic hose's ... WOW!! #20
diamond and Roc, Thanks for the great info on the hyd hoses and fittings. I want to add a remote hyd. filter to my return line,from the fel.. My Bota L3000 has only a screen strainer for protection.Jy.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
11' CONTAINER (A52706)
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
