How much post hole digger can it run?
   / How much post hole digger can it run? #1
Haywire
Central Kentucky
Tractorless :(
How much auger do you think my BX2660 would run? 19.5 PTO hp.
I suppose it would greatly depend on soil conditions.
thanks,
Ian
Thanks... I like the videos.
Ian
   / How much post hole digger can it run? #5
My 20HP MF easily digs 12" hole. More of an issue is what phd can you connect up to a BX.
   / How much post hole digger can it run? #7
Just out of curiosity would the examples shown and the OPs tractor work in heavy, wet red clay?...or would you need more PTO HP and a stronger digger?
Thanks...Tom R
   / How much post hole digger can it run? #8
The auger in the pics is a 9" and if the ground is wet, I dig about half way down and then raise the auger to clean out the dirt and then drill the rest of the hole. The weight that far back is more of a problem than running the auger, the 2660 should run a 12" with no problem, just the weight of a full auger load of wet dirt on the end of that long pole may be more than the lift will raise, just drill part of the hole and lift it to empty and then drill some more.
   / How much post hole digger can it run? #10
It doesnt take much power to run the auger but you have to be careful that it doesnt screw itself into the ground. Hold it up after it goes in about a foot and dont let it freewheel especially in soft wet clay or it will screw itself into the ground and since your PTO doesnt have a reverse, the only way out is to take a pipe wrench and reverse turn the PTO shaft to get it "unscrewed". Having done this a few times, I can tell you first hand that you wont be able to turn the auger if it is in up to the gear box. You will appreciate how much work this is after the first time and be more careful on future digs. It can happen in the blink of the eye if you are running lots of RPM and the dirt is hard on top and then gets soft, when it starts going it will go in before you can stop it. By the way, my first auger in was with a 90 HP tractor and it wouldnt lift the auger out till it was at least halfway out of the ground.
   / How much post hole digger can it run? #11
Great input...never used one but I can just "picture" the auger screwed into the nasty clay! It would be a real mess getting it back out. I assume you just run in a short distance and then pull it up to clean off the dirt...and then do another piece...at least in wet, gummy clay? Thanks...Tom R
   / How much post hole digger can it run? #12
I am still sitting here picturing a post hole auger driven deep into my really tough, gummy, hard wet clay...it would be just like a big lag screw powered into a huge beam...with no reverse on the ratchet :) Tom R
It would require a long pipe wrench for reverse. Read that somewhere recently.
   / How much post hole digger can it run? #15
The PHD actually belongs to my son, I just borrow it when I need it, he bought it at TSC, don't know the name brand.
More than likely a Landpride, thanks.
   / How much post hole digger can it run? #16
From reading I thought one of the "limiting factors" on "how much" was the ability to get the auger pto box high enough so you could easily get the auger in straight. Thus on the smaller BX's they have enough HP to run a bigger auger but getting it off the ground was the problem.
   / How much post hole digger can it run? #17
The pictures I posted is a full size PHD on a BX2200, the second picture shows plenty of ground clerance.
   / How much post hole digger can it run? #18
I have drilled hundreds of holes with my PHD and never ...ever gotten it stuck in a hole..All you do is when you want to remove it from the hole you have drilled is keep it turning and lift up on your 3pt lever but be careful since if you come up out of the ground with the auger spinning loose and wild it can go anywhere...keep in mind the hole you are drilling is all that keeps the auger under control, once you bring it up above the lip of the hole ...all bets are off and it will swing wildly so you have to be careful in raising it up as you put the power to it through the PTO..
I talked to a professional fence intstaller once about the dangers when he was using a post driver to put some posts in for me that I could not get to about and he said the most dangerous is the PHD...not the post hole driver. Drilling is more dangerous than driving !
   / How much post hole digger can it run? #20
This type of auger makes a huge difference drilling holes. The staggered teeth don't walk when starting a hole and take less power to dig. This is a Bush Hog auger with Bear Claw replaceable teeth.
2016 Nissan Quest Van (A59231)
2016 Nissan Quest...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61306)
2020 Takeuchi...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2012 Jeep Compass 4WD SUV (A59231)
2012 Jeep Compass...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
