Subsoiler Qs
   / Subsoiler Qs #1
Haywire
Central Kentucky
Tractorless :(
I visited a used tractor implement place today and they had an old ford subsoiler for $100 that the guy said was made of real steel instead of the junk iron he said the newer aftermarkets were made of.
I thought about using it to break up dirt for pickup with my bucket. Can you run these things shallow, like 6" fairly easily or do they track deep automatically. Maybe I need a plow for such a purpose, they're designed to run shallow.
Ian
   / Subsoiler Qs #2
your 3 point will tell it how deep it can go.
   / Subsoiler Qs
But can you easily limit it or will it be constantly be wanting to dive to the bottom?
   / Subsoiler Qs
Do you limit the angle of the tip (and it's agressiveness) by changing the length of the top link? Forgive the ignorance, never ran a 3ph attachment before. Just kinda feeling this out.
Ian
   / Subsoiler Qs #6
The 3pt will not allow it to sink beyond what you let it.. Hold the lever down until you reach the depth you want, then move it back to the middle. The implement may float up, but it will not go lower beyond the point you set it.
Changing the angle of the tooth on a subsoiler will change the aggressiveness. You do this by adjusting the top link. Shorten the link == more aggressive (points the tooth down thus pulls down more), lengthen the link == less aggressive (pulls down less or rides to the top).
So if you drop the subsoiler to the ground and it won't dig in, shorten the top link until it does. Once at the 6" depth like you want, put the 3pt lever back into the middle.
A box blade is nice to have for this stuff too. More expensive, but by far the most used implement I have. My 5' has 5 teeth that can do what your looking to do with one subsoiler tooth.
Jeff
   / Subsoiler Qs #7
Well, Ian you seem to be having a lot of fun with your new BX. You tell your buds over on AS all about that yet, or still smarting from the guys who wanted you to buy an 85hp M series since a BX wasn't "big enough" for mowing the lawn? :) I got a big kick out of that thread with everyone pushing you into Monster Tractor land...
One thing about tractors is that you quickly find all the neat things you never knew you couldn't live without. Since I got my grapple, I am in heaven for land clearing (after I got past some initial problems with it...). And the winch is a godsend for moving logs around.
But no, I have nothing to add about subsoilers...:laughing:
   / Subsoiler Qs
Ya know, I hadn't considered that about the box blade teeth. Good point.
Dave, the BX is going to be fun in time, but for now I am just learning about the tools that make it more so.
I had one wheel off the ground a couple days ago. The pucker factor was such that I think I pulled a chunk out of the seat. Won't do that again. :laughing:
Ian
   / Subsoiler Qs #10
Jeff
I think that is backwards.
It is just like a rear blade. Longer toplink makes it more agressive.
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
500BBL WHEELED...
206707 (A58375)
206707 (A58375)
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
1761 (A58375)
1761 (A58375)
