Any Interest in this New Invention?
   / Any Interest in this New Invention? #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
A friend of mine invented this device about 6 years ago and Sweet Farm Equipment LLC has been given selling right to it. New Hay Ring Attachment*(Pat.Pend.)*for moving your Round Bale Hay Rings from place to place to keep them out of the mud and keep the feeding area clean and sanitary.*Powder Coat Paint, Perfect for moving hay ring over round bale of hay without getting off of tractor, Ring balances perfectly on spear every time, (Universal Mounting)* Mounts to most any round bale feeder, Keeps feeder out of mud and does not tear up feeders such as when using frontend loaders, Adjustable receiver (up or down to fit your spear),Save your back and not get your shoes muddy, When one hay ring wears out, this device can be removed and put on another ring, UPS Shippable* 38 lbs.**Note:* This item is patented and cannot be reproduced in any form or modified. $75 each + UPS. Ken Sweet
More pictures. Ken Sweet
   / Any Interest in this New Invention? #3
Whats the cost on something like that
   / Any Interest in this New Invention? #4
nevermind i see the cost now.
   / Any Interest in this New Invention? #6
Dont own a single hay ring but if I did and needed to move it for the price that would be great. Cool idea
   / Any Interest in this New Invention? #7
Just so I understand,,,,this is an attachment that fits on a hay spear to pick up a hay ring ?
   / Any Interest in this New Invention? #8
I believe you put one on each hay ring then insert your hay spear into it to pick it up.
I wouldnt buy one, it was fun rolling the hay rings around like hampster cages.
   / Any Interest in this New Invention? #9
Might be handy if you only have a 3 ph spear but most FEL spears work great on their own accord
   / Any Interest in this New Invention? #10
i use a fork on the FEL.
   / Any Interest in this New Invention? #11
Yeah, wouldn't expect to spend money on something like that unless I'm big on moving a lot of hay rings around on a routine basis and I didn't have an FEL which is probably unlikely. I could fabricate something just like it if I needed out of all the myriad bits and pieces of tubing and channeling in my scrap yard in an hour or less. An old bit of drill chain welded to one of the vertical supports would do the same thing. Five minutes work.
Not to be negative, just honest.
It clamps to the hay ring and you slide a rear or front spear into to lift and relocate. Ken Sweet
   / Any Interest in this New Invention? #13
I can see the benefit of having one but I also agree that I would have to have a lot of hay rings to move around regularly before I could justify the expense.
Are you getting any feedback from the people who have purchased them?
   / Any Interest in this New Invention? #14
If it extended the life of the hay ring it would pay for itself quickly. I've seen more hay rings ruined from tractors than from cattle.
   / Any Interest in this New Invention? #15
The FEL spike works great ... and yes a careless operator can wreck a hay ring. I wonder how tough it would be to get off? Some of my hay rings are 7 years old ... if that unit bolts on I bet after that many years a bolt would be hard to break loose.
   / Any Interest in this New Invention? #16
i personally think is a pretty great idea for older guys like my neighbor.. he is getting on in years.. and still takes care of the cows.. well, something like this means he doesn't have to lift the ring out of crap.. mud.. and what ever else.. all the better. looks like it lifts high enough to put over a new round bale for feeding..
great idea.
great idea.
That is what they are designed for. To keep you in your tractor seat and out of the mud and away from any unruly cows. We have used front loaders for years and when moving rings, we usually misjudge where the loader is and bend the rings. Ken Sweet
   / Any Interest in this New Invention? #18
I use a three point spear and here is why I wouldn't buy one. In reality, you've got your ring sitting on slightly uneven ground. Your cows have been crapping on the ground all around it adding to this. Your spear has some movement side to side. Now I'm going to try to back my tractor up and spear this small hole with the end of my spear. I may be wrong but I just can't see it being handy in a real world application. Maybe if those guides were somewhat wider, I don't know.
If you can center up on a round bale of hay when you spear it, you can easily hit this lead in. Ken Sweet
   / Any Interest in this New Invention? #20
Put a little hair around it. :laughing:
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 International Maxxforce DT (A53317)
2014 International...
2019 Yongfu Scooter (A59231)
2019 Yongfu...
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
