Snowblower electric chute rotator motor resource.
   / Snowblower electric chute rotator motor resource. #11
Hi Piloon,
Where abouts in Canada or Quebec can you get an electric winch big enough to do the job, for $50 !!!!!!! Sounds like you got one heck of a deal.
Care to share your contacts ;);)
Thanks :thumbsup::thumbsup:
Jim
Canadian Tire (like Harbor Freight in US) and probably Princess Auto often have sales on them. (I did see once at $39.00 in sales flier at CTC this fall)
LOL, I even got lucky at a yard sale for $5.00 but it needed a set of brushes.
Full retail is generally about $79.ish and still a good deal IMHO.
   / Snowblower electric chute rotator motor resource. #12
Piloon,
Yes, you are right. I have just seen a complete electric winch on sale for $48.99.
For that price it would be a real cheap rotating mechanism. My idea is to connect it directly to the hand cable shaft and since it is a dual directional motor, would rotate the chute either way using the already existing wire cable. Looks like I am gonna be doing some shopping in the next few days for an electric winch to convert my old snow plow chute hand crank mechanism :D:D:D.
Thanks for the tip and idea - sure beats messing with the hydraulics - they can get expensive quickly.
Chopped
Your cheap winch is identical to the one I have just seen on sale for $48.99 - and yes, for what I had in mind, should be more than adequate.
Cheers
Jim
   / Snowblower electric chute rotator motor resource. #13
I just bought one at ctc and installed it last week. Works like a charm. I had to remove the existing crank as I had installed a cab and it would hit it when blower raised all the way. I removed the cable from the winch, (it's held in with allen screw) and used a part of that cable to rotate the chute.
I welded a mounting platform for the winch on the top of the post for the top link. I wrapped the cable several times around the winch drum and did not anchor it to the drum(used it like a windlass). I took one end of the cable around the chute and anchored it with a clamp to where the original cable was connected. I cut the cable so the other end could wrap around the chute the other direction and used a spring of an old bed spring to keep a tension on the cable. The cable wraps on the drum well but it is rubbing on the end bells of the drum, I believe I will put a simple fairlead on it to prevent this - keeping my eye out for something I can use for this. I'll take a picture tomorrow when it gets bright out.
Certified 1500lb Dual Line Electric Winch | Canadian Tire
   / Snowblower electric chute rotator motor resource. #14
Pictures of winch on snow blower.
   / Snowblower electric chute rotator motor resource. #15
Hi DonnieP,
Thanks for the pictures - they are exactly what I had in mind. Sure gonna be nice to be able to rotate with out having to lift the blower to do it !!
Cheers
Jim
   / Snowblower electric chute rotator motor resource. #16
Had you mounted the winch with the drum vertical, as I did, you would not need fairleads.
Actually a nice and easy mod, is it not.
Nice going!
   / Snowblower electric chute rotator motor resource. #17
Piloon, You're probably right about mounting it vertical. Maybe when the warm weather comes I'll look at that as an option - don't have a warm, dry place to work on it. Yes, it's an easy mod. I had a piece of 1/4" plate about four inches square, drilled two hole in it for bolting the winch down and then put a couple of strong tack welds down to hold it in place. I didn't weld it in solid, in case it didn't work.
Donnie
   / Snowblower electric chute rotator motor resource. #18
Now for a deflector one.lol I wonder if it could be rigged with a realy solid string to pull it downward, and then another el cheapo winch to pull on it for ''up'' A single cable hook to it and the spring would constantly be pulling it downward..????
   / Snowblower electric chute rotator motor resource. #19
DonnieP, your set up is brilliant, I'll be copying exactly for my three point blower. I plan on using a linear actuator for chute tilt, although in theory winch would work perfectly well. Thank you for posting, I printed your pictures, they are supper helpful.
Joel
   / Snowblower electric chute rotator motor resource. #20
I was able to use a crown vic window motor on my 2750. The gear on it fits right in a 3/4" 6pt socket and the shaft diameter on the 2750 also just fits in a 3/4" socket. I cut the drive part off the socket and I had an easy drive shaft hookup without modifying any factory parts.
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
Case skid steer wheels and tires (A56438)
Case skid steer...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
