Just had a big hole dug in my front yard
   / Just had a big hole dug in my front yard #181
My fuse box had 30 amp screw in fuses in it when I moved in. The only reason I can see for having bigger fuses is if the correct sized ones kept blowing. Of course I had multiple wires attached to each terminal within the fuse box, too. I am VERY pleased to have it updated to the point it's at.
I'm expecting the electrical inspector to come by any day now. The General Contractor (My wife) was going to call today. I plan on having a few small things that I'll have to fix. It seems that's always the way it goes, but I tried to do it all to code.
good for you to have gotten rid of the old thing. alot of people think that they can just go and put larger fuses in and all is well. doesnt work that way. its the size of the wire that is the deciding factor. a current production #10 wire is rated at 30 amps. anyone can put it in a 70 amp breaker...but if the wire shorts out, it will melt and probably catch fire BEFORE the 70 amp breaker trips. The real old style wires in 70 yo buildings cant even carry as much current as current wires. does get kind of scary at times what i see.
Question to eepete or anyone who cares to volunteer an answer...
Is there a way to shield the network stuff (cat. 5, Coax) from the AC stuff when they have to be together? There is one location where I couldn't figure out a way to run the wires except to have the network and the AC parallel for a short distance. Is there some kind of foil or shield that I can put between them to minimize interferance?
   / Just had a big hole dug in my front yard #183
There is a shielded Cat-5, but that would require forethought or replacement. The purpose of using twisted pairs in the cable is to minimize or prevent crosstalk or interferance. As for the coax, the outer copper is a shield and can be grounded to pull off interference if needed.
I wouldn't worry about it unless you find that you have issues.
   / Just had a big hole dug in my front yard #184
If your coax is connecting to your cable TV or satalite system it should already be grounded where it enters the house.
   / Just had a big hole dug in my front yard #185
i have my phone and cat 5 in their own conduit, but only 6" away from the power feeders ....ive never had any interference. cat5 is twisted in such a way that it pretty much prevents any problems. my cat5 runs a computer cnc plasma cutter....never have had any problems. and can communicate with computers indoors just fine
   / Just had a big hole dug in my front yard #186
There are two ways that interference gets onto wiring: Electrostatic (or E-Field) and Magnetic. For the purpose of this discussion, we'll include Radio Frequency (or RF) as part of electrostatic.
Electrostatic shielding can be done by any piece of metal. So you can have the braid on a coax, the foil shield on a cable, or have the wire in a metal pipe. Typically the metal is connected to ground. The electrostatic/RF field can not penetrate the metal very well, so the wires inside of the shield are protected. Different types of shielding and grounding systems have different amounts of percentage of shielding you get. But unless you are close to a high power radio transmitting site things like coax and foil shielding will work just fine.
The way to shield against magnetic fields is with a twist of the wire. How often the wire is twisted depends on how high of a frequency you have on the wire (or in geek speak "what is the bandwidth of the signal"). If anyone can recall back to the days of open telephone wires (or look at pictures), every few poles there is what was called a transposition bracket which swapped the sides of the wire as they were on the poles. For telephone bandwidth, that was good enough. As you go from cat3 to cat5, the big change is the amount of twisting and the consistency of the twist. That's why cat5 can handle higher bandwidths (now measured in bits per second instead of some frequency) than cat3.
The predominate mode of interference from AC power is magnetic. So the twists in the cat5 cable go a long way to protect it from interference. Coax is harder to shield, and if you have baseband video on the coax you can often see problems with shielding as the "hum bars" that will be slightly but annoyingly visible. When there is RF on the coax (like your satellite dish, cable, or TV antenna) the interference from the AC does not have much energy at the frequencies that are on the coax, and things work out fairly well. FWIW, I always use quad shielded coax because it's easier to be cautious than lucky.
One more interesting thing about fields: The energy falls off as the inverse of the square of the distance. Oh geez, don't yell "No, Not MATH:shocked:" it's easy to explain this :laughing:! If you double the distance between two wires, the field strength is 1/4 what it was. If you move the wires to 4 times further away, the field strength is 1/16th what it was. So take the "new distance" between two wires. Square that distance, and then take the reciprocal (i.e. 1/<the number>). A little bit of distance makes a big difference in the levels of interference.
Practically speaking: Imagine you had AC and CAT5 wires that were laying on each other, which might put the wires 1/4" apart. Now move the wires so they are 2 inches apart. This is 8 times the distance you originally had, so the field is 1/64th as strong. Pretty good deal for such a small change in spacing.
So when running wires, you want them to cross at right angles as much as you can. You do not want to parallel them if you can help it. And you want to get as much distance as you can between them. More than 4 inches of distance and you'll never see the difference. Going to great lengths to get more than 4 inches of separation is not worth it.
Drill and use separate holes for AC and for low voltage. The inspectors will want to see this. Use the wire supports to keep the wires apart.
Here are some pictures. My helpers when I wired my place got the low voltage on both sides of the AC in a spot. So I took a piece of pipe insulation and went from 1/4" apart to about .75" apart or 1/10th the coupling. And that is over a small area.
You can put the pipe insulation on either wire (AC or LV- you can see examples of both in the pictures), but if it's more that a short piece of insulation I'd go for the Low Voltage and not the AC wiring.
Finally, you can see where I came through a smoke block and had separate holes for LV. Note also that I kept some of my coax away from everything (by about 4 inches). In fact, I tended to group my wiring into these groups:
CAT5, speaker wires, wires that ran relays, coax, and AC. All those types had some separation between them. If you look in the upper left of the picture, you'll se a bunch of gray wires. These go to coils of relays for turning on lights. I also had a run of two coaxes from the attic to the basement. These went to my off-air antennas. I had those 1' away from everything up until the last 12' before they came into the room with all the connections. I also ran an 18 gauge wire for powering amplifiers for these antennas so the signal levels would be stronger both for interference and signal loss reasons.
One trend that has made the interference problem better is that all things electronic have to pass radio emissions testing. So things like dimmers tend to not produce the "hash noise" they used to when they first came out. There is also less motor noise. This is nice because hash noise _is_ RF and might require that all this cat5 cable be shielded. But with reduced RF from the AC lines, it boils down to a magnetic shielding problem that is solved via the twist in the wires.
Also keep in mind that virtually every protocol a computer runs when doing communications via Ethernet on CAT5 cable has error detection and a means of correction. So a little once in a blue moon hiccup from something big turning on or a lightning storm isn't a problem. Relative to the speed of light, a blue moon could be every couple minutes or so.
So to the OP, parallel for a short distance is OK, try to get 2 to 4 inches between the wires. The cat5 will be just fine for your network stuff.
Clear as mud?
Pete
...So to the OP, parallel for a short distance is OK, try to get 2 to 4 inches between the wires. The cat5 will be just fine for your network stuff.
Clear as mud?
Pete
Sounds like I need to get some of that pipe insulation for the few spots where I have wires all together. Thanks for the response.
   / Just had a big hole dug in my front yard #188
There is ONLY one way to solve your problem! You must wrap your head in heavy duty aluminum foil and make sure you locate yourself where ever there seems to be the most interference. Once you do the above you will feel relief from all crossed wires in your house. Repeat as necessary. :D
   / Just had a big hole dug in my front yard #189
You can also use the wire staples to pull the AC away, or put in a wire staple and use a tie wrap to pull the LV away.
I also like those holders that hold up to 4 AC wires. They can help hold things out and away. You can see a white on in one of the pictures where I put the hose insulation on the LV wires to get a little distance to the big black kitchen range power wire.
I hope Coyote machine can post a picture of his head wrapped in aluminum foil. It will take a picture to make sure we all get that right.... ;). Also, remember that the aluminum foil only protects agains E-field/RF, not magnetic fields. For that he'll need to find a cobalt-nickle based metal that was hydrogen annealed.
Pete
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
