JD2320 - split SCV hard lines to both mid and rear remotes?
   / JD2320 - split SCV hard lines to both mid and rear remotes? #1
dmay
Gold Member
Winnipeg, MB
2010 JD2320
Hi all hydraulic experts. I've searched and not found a direct match to my idea to split the SCV hard lines. My thought is to remove/somehow use/replumb the factory JD 2320 SCV hard lines through electronic diverter vales so that you end up with both mid and rear remotes that utilize a toggle switch to simply switch between mid/rear remote activation, all factory joystick controlled of course?
Is this possible to achieve?
   / JD2320 - split SCV hard lines to both mid and rear remotes? #2
The idea should work as I understand from your intent. Whether it will work physically might be another dilema for you. I don't see where the oil would care that it was being diverted to the front or to the rear. ;)
I'd be interested in seeing a layout sketch and for sure, some build pics as you go. :)
   / JD2320 - split SCV hard lines to both mid and rear remotes? #3
I've also been looking at mounting two 9-7852 at the rear. Put quick connects on rear facing ports C2/C3, 90 degree fittings on the others where P1/P2 is from SCV and C1/C4 go to mid mount quick connects. This way the de-engerized state is normal flow to mid and energized activates rear.
Surplus Center - 12 VDC 13.2 GPM SAE 8 DOUBLE SELECTOR VALVE
http://www.surpluscenter.com/Instruct/I9-7852.pdf
I'm not sure if this is the cleanest possible setup or not. I have never done any hydraulics customization before.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #5
Do you have a joystick with PB now?
No. I have the standard mid DSCV loader joystick setup. This is what I want to split. I do not have the optional Power Beyond kit installed. If I understand correctly the PB kit would not achieve the results I am looking for.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #7
Where in the series circuit will you install the joystick? What will the joystick control. Will it be before the FEL valve or after?
If these valves are in series, one of them will have to use a PB outlet for high pressure fluid downstream.
I wont. They will not be in series.
JJ I'm obviously not explaining myself correctly. Let me add a pic of the current SCV pipe kit and try again. This is how the hydraulics are plumbed to the mid quick connect couplers now. What I am saying is to remove this kit and change the plumbing so that one set of hydraulic lines go out of the SCV into one 9-7852 P1/P2 then routes out to the two circuits. C2/C3 become my new rear quick connect couplers. C1/C4 back to the mid quick connect couplers. Repeat for the second set of lines going into a second 9-7852, second rear quick connect couplers and back to the second mid quick connect couplers. In default unenergized mode the mid quick connect couplers are live. When 9-7852 are engergized the rear quick connect couplers are live. Use the loader joystick to control all.
All theory from a hydraulic newbie for now.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #9
Hydraulics
Type Open Center
Pump Rated Output, gpm (L/min.) 5.6 (21.2)
Steering 2.2 (8.5)
Implement 3.4 (12.7)
Pump Type Gear
Maximum Operating Pressure (PSI) 2421
You have an open center hyd system, and all valves have to be in series. You have to use the FEL valve as it has the PRV. If you interrupt the hard lines, the valves you install have to be in series. You must be using the tank port for the 3pt now, since you said you did not install the PB. Can you describe the routing of the fluid from pump to tank? In most cases, it goes like this. Pump to FEL to 3pt, tank.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #10
Hydraulics
Type Open Center
Steering 2.2 (8.5)
Pump Type Gear
He is not talking about adding another valve, he is talking about splitting the stock SCV outputs to 2 sets of couplers and using a director valve to decide which set of couplers gets the pressure when the stock valve is actuated.
OP, it will work just fine. Deere actually makes a loader/mower diverter valve (LVB25822) so you can have the MMM and loader on @ the same time without disconnecting one or the other. 2 of those and you have what you want.
Glad you understand I'm talking about diverting flow only. :)
The LVB25822 is not quite what I want. It is mechanical. It uses and alters the front side of the mid quick connect couplers. I dont think there is room for two. It does not add rear remotes.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #12
The problem is JJ does not understand how JD mounts the valves...That why he is confusing all of you.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #13
Yes, very possible-except for the very limited real-estate available on your 2305, and the steel hardlines going from the SCV to the QD's.
Your best bet is to add a new valve-probably on the ROPS just above the fender and feed it with the PB lines that would feed a backhoe. Simulat to these:
Installing a 2 spool SCV on a JD 2320 - TractorByNet.com
2520 - Rear Remotes Added - TractorByNet.com
Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 - TractorByNet.com
It may cost a little more this way-but in the end you'd be much happier, I promise.
Thanks Kenny. Those are great links and great detailed valve installations from members. I of course was hoping you might get involved in this thread and say yes it can be done easy just the way you want... Oh well. If a new valve will make me much happier, guess I will take your sage advice. I have some questions on the PB. I think I'll start a separate direct thread on this.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #15
Your welcome...I just replied to your other thread as well.
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2019 CATERPILLAR 930M WHEEL LOADER (A60429)
2019 CATERPILLAR...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
