Towing a 12K rated trailer in Pa
   / Towing a 12K rated trailer in Pa #1
Guesseral
Erie Pa.
Montana R4944, Ford Jubilee, Ford 621, Ford 841
Does anyone know what the requirements are to tow a 12K trailer in Pa? I am looking to buy a dump trailer to haul firewood and other stuff, but i want it long enough to haul my tractor (montana R4944) to the site to load firewood into the trailer. I need the trailer to be 14' to get the tractor w/FEL on the trailer, I guess I could go with a 12' trailer and put the bucket up over the front but in any event the only ones I can find in that length are rated for 12K. I would like to find one the right length and a 10K rating because I guess there isn't any problem if the trailer is 10K or less but I don't think they make one with that rating. Well in any event I have a 2005 Dodge 2500 4x4 quad cab. I know it will haul what I want because I have done it before, but from what I understand I am not legal something to do with a combination license. Any help out there? :confused:
   / Towing a 12K rated trailer in Pa #2
If the combined 'registered' gross weight of both vehicles exceeds 26,001 lbs, 'and' the trailer is in excess of 10,000 lbs you would need a non commercial class A.
Doesn't sound like this is the case.
   / Towing a 12K rated trailer in Pa #3
A quick call to the local DMV will get you the requirements.
gernerally speaking over 10K all axles need brakes.
10K and up you will need a Cat V hitch or cat IV with an equalizing hitch.
If the truck you pullign with is callled as a road tractor might require a CDL of sorts, if just a pickup you should be good to go.
   / Towing a 12K rated trailer in Pa #4
You should not need anything special. I would get a 14K trailer if I were you though in that length. The trailer is going to weigh in the 4,200# range empty leaving you with plenty of payload. On a 10K or 12K trailer it will be a little light on load capacity.
Chris
   / Towing a 12K rated trailer in Pa #5
Your trucks GVWR is around 9,000 lbs so even a 14k trailer would keep you well under 26k combined GVWR so you would not need a CDL.
Dodge Towing Guide - By Vehicle
   / Towing a 12K rated trailer in Pa #6
If the combined .... gross weight (rating) of both vehicles exceeds 26,001 lbs, 'and' the trailer is in excess of 10,000 lbs (GVWR) you would need a ..... commercial class A.
Fixed it. ;)
   / Towing a 12K rated trailer in Pa #7
That is a bit misleading. If the pickup was an F450 it would have the same drivers license class requirements as a tandem axle Kenworth. Same if the trailer was larger, like a 20k GVWR for example, the DL requirements would be the same for his 3/4 ton as a "road tractor".
The Pa regulations on the site are very bad. They really don't tell you anything other than what you don't really want to know! The whole site runs you round in circle's but never give you the information you were really looking for. Beleive me I have tried!
   / Towing a 12K rated trailer in Pa #11
You may find this helpful.
http://www.dmv.state.pa.us/pdotforms/fact_sheets/fs-cdl.pdf
PennDOT Driver and Vehicle Services - Classes of Licenses
Based on those 2 links you do not need a class A (combination) license.
We may have misunderstood you though, are you asking about a combination registration?
   / Towing a 12K rated trailer in Pa #12
Here is were you want to go it is buried in their pages but I had to find it for a friend with a motor home <26,001 lbs
But it is in plain English.
You would be in class A or B non commercial as long as you don't get compensated for the "work" that would put you in to commerical and a whole different can of worms
What Class of Driver's License Do You Need?
In Pennsylvania, driver痴 licenses are issued specifically for the class and type of vehicle you operate. Therefore, the class of driver痴 license you should have depends specifically upon the type of vehicle you operate. Generally speaking, the majority of applicants for a Pennsylvania driver痴 license will be operators of regular passenger vehicles, pick-up trucks or vans.
Classes of Driver's Licenses
Non-commercial Driver's Licenses
  • CLASS A (minimum age 18): Required to operate any combination of vehicles with a gross weight rating of 26,001 pounds or more, where the vehicle(s) being towed is/are in excess of 10,000 pounds. Example: Recreational Vehicle, when the towing vehicle is rated at 11,000 pounds and the vehicle towed is rated at 15,500 pounds (total combination weight of 26,500 pounds).
  • CLASS B (minimum age 18): Required to operate any single vehicle rated in excess of 26,000 pounds. Example: Motor homes rated at 26,001 pounds or more.
  • CLASS C (minimum age 16): A Class C driver痴 license will be issued to persons 16 years of age or older, who have demonstrated their qualifications to operate any vehicles, except those requiring a Class M qualification, and who do not meet the definitions of Class A or Class B. Any firefighter or member of a rescue or emergency squad who is the holder of a Class C driver痴 license and who has a certificate of authorization from a fire chief or head of the rescue or emergency squad will be authorized to operate any fire or emergency vehicle registered to that fire department, rescue or emergency squad or municipality(emergency use only). The holder of a Class C license is authorized to drive a motor-driven cycle with an automatic transmission and cylinder capacity of 50 CCs or less or a 3-wheeled motorcycle with an enclosed cab.
  • CLASS M (minimum age 16): A Class M driver痴 license will be issued to those persons 16 years of age or older who have demonstrated their ability to operate a motorcycle or motor-driven cycle. If a person is qualified to operate only a motorcycle or motor-driven cycle, he/she will be issued a Class M driver痴 license. If you test on a motor-driven cycle, an "8" restriction will appear on your driver痴 license. This restriction prohibits you from operating a motorcycle. If you test on a 3-wheeled motorcycle, a "9" restriction will appear on your driver痴 license. This restriction prohibits you from operating a 2-wheeled motorcycle. Pennsylvania Motorcycle Operator痴 Manual (PUB 147) or the Mopeds, Motor-Driver Cycles and Motorcycles Fact Sheet located on PennDOT痴 Driver and Vehicle Services website in the Motorcycle Information Center.
Commercial Driver's Licenses - Classes A, B or C
  • CLASS A (minimum age 18): A Class A license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any combination of vehicles with a gross combination weight rating of 26,001 pounds or more, provided the gross vehicle weight rating of the vehicle or vehicles being towed is in excess of 10,000 pounds. The holder of a Class A license is qualified to operate vehicles for which a Class B or Class C license is issued. Where required, appropriate endorsements must be obtained.
  • CLASS B (minimum age 18): A Class B license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any single vehicle with a gross vehicle weight rating of 26,001 pounds or more or any such vehicle towing a vehicle having a gross vehicle weight rating of not more than 10,000 pounds. The holder of a Class B license is qualified to operate vehicles for which a Class C license is issued. Where required, appropriate endorsements must be obtained.
  • CLASS C (minimum age 18): A Class C license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any single vehicle with a gross vehicle weight rating of not more than 26,000 pounds or any combination of vehicles, except combination vehicles involving motorcycles, that does not meet the definition of a Class A or Class B vehicle. Where required, appropriate endorsements must be obtained.
NOTE: You must be 21 years of age or older to operate a Commercial Motor Vehicle on an interstate (traveling between two or more states). This applies to ALL classes.
In addition to the CDL classes, there are also special endorsements and restrictions that you must have to drive certain types of commercial vehicles. They are:
Endorsements/Restrictions
Endorsements The following authorizations are required when operating vehicles of the type listed:
H - Required to drive a vehicle with hazardous materials placards (you must be 21 years of age).
N - Required to drive a tank vehicle.
T - Required to drive double and triple trailers.
P - Required to drive a vehicle designed to carry 16 passengers or more including the driver (buses).
S - Required to drive a school bus. Designed to carry 11 passengers or more, including the driver.
X - Represents a combination of the hazardous materials and tank vehicle endorsements (you must be 21 years of age).
Restrictions The following restrictions prohibit you from operating certain type vehicles:
L - Restricts the driver to vehicles not equipped with air brakes.
B - Passenger endorsement restriction cannot drive Class A buses.
C - Passenger endorsement restriction cannot drive Class A or B buses.
   / Towing a 12K rated trailer in Pa #13
You would be in class A or B non commercial as long as you don't get compensated for the "work" that would put you in to commerical and a whole different can of worms.
No he wouldn't.
He falls under a Non commercial class C. (CGVWR or GCWR isn't over 26k)
   / Towing a 12K rated trailer in Pa #14
I don't have the answer either, but I'll throw in what I've learned. I am also looking at purchasing a 12k trailer to haul my TC33 and implements with an F350. With that combination I am under 26,000 lbs, so I don't need a CDL. This is all unconfirmed opinion based on discussions I've had but may point you in the right direction to find the real answers.
The question has nothing to do with the license of the driver, but the registration of the vehicle and trailer. If the trailer is over 10,000 lb, you are required to obtain a 'combination' registration for the truck and trailer together. To get this you need to contact the manufacturer of the tow vehicle with your VIN number and get a letter stating towing capacity of the vehicle. Then you can file for a 'combination' registration throught the state. I'm not sure, but this may also require inspection every 6 months instead of once a year and a medical card to accompany your drivers license, just as is required for vehicles over 17,000 GVW.
I have gottm my letter from Ford, but have not pursued it any further.
Jim
Yes I was talking about a combination registration, and what would be required to get one.
   / Towing a 12K rated trailer in Pa #17
No he wouldn't.
26k)
I was trying to make the point the information is there on the web and there are non commercial licenses available in this state if necessary for your weight class.
   / Towing a 12K rated trailer in Pa #18
Tommu56
Always thinks he knows everything!!!!!!!! He missed the point as always!!!:confused2:
   / Towing a 12K rated trailer in Pa #19
How so wise guy?
Nice first post. :rolleyes: Welcome to TBN.
Were you not saying that he needs a class A or B?:confused:
Either way, being compensated or not has little to do with whether you need a commercial or non commercial.
I am a not for hire private carrier but still need a CDL.
   / Towing a 12K rated trailer in Pa #20
So if you are a guy that is in to tractor pulling and have 2 tractors trailer and a F650 and go to tractor pulls and the whole rig weigh's over the magical 26001lbs in PA and that is were the OP resides you can get get a non commercial A class license and save some money any headaches of a CDL.
The same go's for a class A motor home that hits the 26001 mark you can opt for a class b non commercial.
Class C excludes the all the above in Pa.
I grazes over Wisconsin regulations and doesn't appear they give you that option at least in pa you can get a choice.
2021 CATERPILLAR 926M WHEEL LOADER (A60429)
2021 CATERPILLAR...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
1981 Kari Kool 6,500 Gallon T/A Tanker Trailer (A59230)
1981 Kari Kool...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
