New Member-US Refurb Yanmar New Dealer
   / New Member-US Refurb Yanmar New Dealer #1
US Refurb Yanmars
Hello, My name is Chuck Kay and I am in Cumming, GA which is about 60 miles north of Atlanta. I am keeping 10-12 Yanmars in stock along with LMC Implements.
I am a new US Refurbished Dealer but have some experience and can be a source of info for obtaining parts etc.
I have enjoyed reading in the forums.
   / New Member-US Refurb Yanmar New Dealer #2
Welcome to TBN. :)
   / New Member-US Refurb Yanmar New Dealer #3
:welcome: to TBN! i have a Yanmar 169D and love it! Glad to hear of another Yanmar dealer out there. I already have a question for you, my 169D 3 point hitch will only lift about 150 pounds right now, i cant lift my 300 pound box blade any more. So where do i look to find the problem? I was told it was a seal or a hydraulic screen but since i don't have the manual i am unable to locate the problem.
Hate to do this on my first question but please let me refer you to Steve at Spalding Tractors in Griffin, GA he has been a dealer for 8 years. I am not familiar with your Model # but think he will be able to help. His site is spaldingtractor.com.
Thanks, Chuck
   / New Member-US Refurb Yanmar New Dealer #6
Hey there! Welcome to TractorByNet! :D I have moved your thread to the Yanmar Forum. You will have better luck finding what you need there. :thumbsup:
I do not handle that model Refurbished Yanmar but try this. Under your seat you will see a vent. It is candy cane or "U" shaped and the open end points down. It is probably clogged, just take a wire or we use a larger cable tie and run it up in there several times and that should open it up. If that does not work under the tractor at the back, almost under the rear axle, on the left side there will be a small plate, maybe 3" or so with 3 nuts holding it on. Get something to catch the 3-4 gallons of trans-hydraulic fluid that will come out and take that plate off, there is a screen filter there. Clean and replace it, if you put in new fluid make sure it is trans-hydraulic fluid. Good Luck, Chuck Kay
   / New Member-US Refurb Yanmar New Dealer #8
When you stated vent is that the small tube under the seat? That thing leaks oil all the time on the ground so in late 2009 we put a plug in the end to minimize the oil spills on the concrete floor and it worked then. I got the manuals for my tractor now and have located the hydro filter. I plan to fix it soon, i need to buy me a new chain saw first though. :p I got 5 gallons of hydro fluid from Napa last week so I should be good on that. The manual says that I should take off the rear wheels to access the filter. Is that a good idea? Mine are ballasted so they will be fun to wrestle with.
   / New Member-US Refurb Yanmar New Dealer #9
In my way of thinking if you have that vent stopped up you are going to have more condensate forming in the transmission. If fluid is coming out the vent tube it must surely be over full. If the manual says take a rear wheel off I would take a rear wheel off. Just the side the screen is on. Just my opinion.
   / New Member-US Refurb Yanmar New Dealer #10
I'm an authorized Yanmar dealer & can supply you with manuals & parts. Is the transmission jerky? If so you have a plugged pickup screen. Once the 3 point is up, close the valve under the seat & see if it settles. If it does it probably is bad lift cylinder orings.
2014 F-150 STX (A56438)
2014 F-150 STX...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
2020 DRAGON ESP...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
1995 Polaris 300 Explorer ATV (A59814)
1995 Polaris 300...
