Setting poles in the ground
   / Setting poles in the ground #1
MillWeld
Gold Member
Durham NC
Ford 641
I'm planning a pole shed and will be using old utility poles. They will probably be 13 -14' long and set in 30 - 36'' holes. I have a tractor with boom which will lift to about 8 feet and winches and come-alongs. How can I set these poles in the holes safely with this equipment? I've built sheds like this before with the same equipment but it was a little dicey with the utility pole leaning too close to me while on the tractor. Don't want to take that risk again. Looking forward to any comments.
Bob
   / Setting poles in the ground #2
I don't think you can do this safely solo I'd get two other friends and a couple of ropes. Use tractor to get the poles off the ground and friends finish the lifting.
Mike
   / Setting poles in the ground #3
I used logs, 12-15' long and my FEL. A boom pole should work as well or better. I did it safely by myself.
I dug the holes 36" deep. I put the end going in the ground next to the hole. I had a piece of old tin and laid the pole on it to help from knocking dirt back in the hole. I lifted the other end (top) with my FEL to get it started then used a chain to act as a choker. The pole would slip thru enough go in the hole. Then lifted higher until bottom started dropping into place. When the pole goes...it goes in the hole! 12-15 poles zero problems setting. There maybe a picture on the Iron Hill Shed Project.
BTW, I dug all the holes. Drove every nail, screwed every screw, lifted every board etc. by myself. I used a few special words along the way with those oak boards too. Those 16' 2x6" were BRUTAL!
   / Setting poles in the ground #4
stand them by hand. 2 or 3 high school football players should be able to do it .they can even help you dig the holes and hang the rafters.
   / Setting poles in the ground #5
I have done this repeatedly using my loader, my bucket with a hook welded on dead center and a logging choker chain. Since I have tines in the front of my bucket when I lift the utility pole I can get the pole centered on the bucket and then just use the curl function to get the butt of the pole off the ground. Drive to the hole and set it in. I use 16' poles for fencing. My tractor is large enough for me to feel safe. I tried it with my B7800 but there was not enough tractor weight or loader lift height to do the size of poles, some are 16" at the butt, and feel safe. Once I got the hang of it it worked pretty slick.
   / Setting poles in the ground #6
How big is you tractor? That will make a big difference in how you can do it.
We have a 70hp tractor that the loader will lift to 11' and we also have pallet forks so this is how we do it. We adjust the pallet forks so that the space between them is the same or a little bigger than the size of the post we are setting. I then line the tractor up so it is in line with the pole with the end that is going in the ground farthest away from the tractor. I put a chain between the pallet forks and under the pole and then curl the fork tips up while driving forward. This gets the pole coming over the top of the pallet forks towards you and it is between the forks so it can't slide off either side. I lift the loader enough that the pole goes over my head as I drive forward till there is 8 to 9 feet of pole left below the pallet forks. I then hop off and chain the pole to the top part of the pallet fork frame. This is ~2' above the forks so it works to keep the pole straight. I can now drive wherever I need to and then just raise the loader and tip the end of the pole down till it is pointed straight up and down and then lower it into the hole. We can do this with poles up to about 25 feet long.
I don't know if that makes sence. It is hard to explain but it is really easy to do in real life. If you tractor is big enough to do it like this it works very well and you could do the same thing with a bucket, you would just have to chain the pole above and below the bucket to keep the pole from rotating. If your tractor is too small for this then I don't really know how you would want to go about doing it. Good luck.
Ed
   / Setting poles in the ground #7
he does not have a fel.i also put them in with a loader.but 3 high school football players for a day is a lot less than a loader.
   / Setting poles in the ground #8
Bob
I set all my pole barn poles by myself with my boom pole on back of my Ford 3055. I would drag the pole to the hole, then position the traction to lift the pole, turning the tractor as I backed up and lifting the pole at the same time. I had the pole chained to the boom so that the butt end of the pole would be heavy. I put in 18 poles like this with the tallest two center poles being 22 feet long. It can be done alone, but real slowly, thinking all moves out carefully.
hugs, Brandi
   / Setting poles in the ground #9
What the **** are you fencing in, a herd of mastadons? Or fencing them out?
Joe H
   / Setting poles in the ground #10
I put in 16' 6x6's by myself, by hand. put one end over the hole, and walk it up from the other end.
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
2016 John Deere Gator (A55973)
2016 John Deere...
1992 Ingersoll Rand (A55973)
1992 Ingersoll...
