Took Delivery of my JD 2320 yesterday
   / Took Delivery of my JD 2320 yesterday #1
Lowgear
Clayton, NC
John Deere 2320
Hello all, My big little tractor arrived yesterday, right now she's hanging out in the garage with the car until the barn gets built. We've got two acres to work with here in NC and I think she'll be up to the task.
Brand new tractor, but a big issue with the CX200 loader not wanting to raise up to full extent; I can get the bucket up to about even with the hood only. I can't see any obvious obstructions on the arms, but surely they tested it when they installed it on the tractor. So unless I'm really that pathetic with a loader...
Second problem, very minor is with one of the pins on the ROPS; can't get the right side in or out without help from the mallet, while the left side goes in and out easily.
Still love the thing thoughk, and can't wait to get the time to put it to work and tame this place. Thanks for the forum...
   / Took Delivery of my JD 2320 yesterday #2
Welcome to TBN. :)
   / Took Delivery of my JD 2320 yesterday #3
Hello & WELCOME to TBN!
I moved your thread to the John Deere Owning/Operating Forum. :)
   / Took Delivery of my JD 2320 yesterday #4
It sounds like one of your quick disconnects on your hydraulics for the loader are not connected right. Shut your tractor off put the bucket on the ground. Release the pressure by moving the loader joystick back and forth and side to side. Then unhook and reinstall each hydraulic disconnect one at a time. Hope this helps.
   / Took Delivery of my JD 2320 yesterday #5
I think UnclePaul gave you the correct answer for your first problem...
As far as the ROPS pin, might just be a little paint or rust in the ROPS brackets. Just polish the holes with a bit of abrasive paper. Not too much...you want the pins pretty snug.
BTW, my Deere is 10 years old and those pins still require a bit of persuasion to get them in and out. ROPS doesn't rattle, so I'm fine with that.
   / Took Delivery of my JD 2320 yesterday #6
I think this may be a feature, not a bug. :laughing: Mine does the same thing. I've been intending to ream the hole for a year but haven't gotten around to it.
   / Took Delivery of my JD 2320 yesterday #7
Congrats on the new machine Lowgear! I'm over in the Zebulon area and just got my 2520 recently. My ROPS pin was really tight at first too but seems to have worked it's way loose after a few times removing and replacing it.
   / Took Delivery of my JD 2320 yesterday #8
Welcome Lowgear.
My ROPS is the same way. It's just from welding distortion. Since I put a on a canopy and front posts to support my canopy, it's a non-issue anymore.
I agree that UnclePaul probably has it figured out. Sometimes those quick-connects can look like they are hooked up completely; but just be out a bit to prevent hydraulic fluid flow.
You guys give good advice and I tried reconnecting the hoses but it didn't work, it was still a simple fix not far from the one you suggested. You're gonna love this; the color coded label for the hoses mixed up the 1 and 3 hose, so they were hooked up in reverse, that's what prevented the loader from raising up more than a little. The dealer just had another with the same problem they figured out how to fix just before coming down to take care of mine. I'll try to attach a picture when I get the chance. Go figure...
Oh, and at the same time the mower deck decided not to lower completely, and that was an even simpler fix; the Rockshaft Control Lever has to be pushed all the way forward not to impede the mower deck, who knew?
   / Took Delivery of my JD 2320 yesterday #11
Congrats on your new machine! Seems like every tractor has it's quirks and "undocumented features" :).
Pete
   / Took Delivery of my JD 2320 yesterday #13
Lowgear....do we get to see pics?:)
   / Took Delivery of my JD 2320 yesterday #14
My pins were so tight that after beating them out (or at least the first one until the bind was releasted ) there was no way that it would go back in. JD service guy couldn't get it back in and ended up taking it into the shop and they had to drill out the excess. Was about 1/4 inch off. I guess it is a common problem.
Pete
I love that term! My tight ROPS pin "feature" is already starting to loosen up a bit. Maybe it's because I've forgotten twice now to lower the ROPS before entering my garage..whoops.
Still had problems with the MMM; very temperamental, either would not lower but half way down, or would go all the way down regardless of height control knob setting. I scalped some turf badly because of that. The guys from the dealership were great and came back for another visit. Turns out the Independant lift kit was not hooked up "independently"; the rockshaft control lever was in direct competition. They disconnected the 3ph from it, made sure the height control knob was hitting the stops, and I'm back in business with a height controlled deck now.
   / Took Delivery of my JD 2320 yesterday #16
Mine was off by about a 1/4" also, I reamed the holes.
   / Took Delivery of my JD 2320 yesterday #17
Tractor? What new tractor? No pics, didn't happen. :laughing:
Congrats on the new 2320. Only problem with mine is not enough seat time.
Good luck,
Steve in NH
   / Took Delivery of my JD 2320 yesterday #18
Been there, done that...
   / Took Delivery of my JD 2320 yesterday #19
Congratulations!
2017 GENIE GTH844 TELESCOPIC FORKLIFT (A60429)
2017 GENIE GTH844...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
