Using a subsoiler as a ditch digger
   / Using a subsoiler as a ditch digger #11
This what I use for trenches. It is a hyd motor turning a 26 in carbide tipped wheel. Does an outstanding job.
You could make something like this with a hyd motor, blade disk, and carbide teeth. Mount it on the bucket , 3pt or make a push/pull trencher.
I also have the subsoiler for pulling pipe.
Is that the powertrac stump grinder?
   / Using a subsoiler as a ditch digger #12
I'm pretty sure it was a close-out at Agri-Supply. They were changing to the fix/solid ones that looked like King Kutter at $50 more. I paid $95 IIRC, when I saw that it was adjustable, I had to have it.
I just looked it up on Agri-Supply and it's still listed but for $129... No photo there :(
3-Point Hitch Middlebuster - Agri Supply
   / Using a subsoiler as a ditch digger #13
Yes, it is a stump grinder/trencher from the early 90's
Thats pretty cool JJ. I think I may want/need something to bury the line while I am at it (since I found out I can).
On a different note I am thinking of building a scaled down sickle mower type contraption for pruning grapes, blackberries and raspberries (I have about 3 acres of them). I want to learn more about a Hydraulic motor that would give me the reciprcating action.
   / Using a subsoiler as a ditch digger #15
...I want to learn more about a Hydraulic motor that would give me the reciprcating action.
You've come to the right place :laughing:
I saw where agrisupply has several of them. I am gonna get one for this very reason... Thanks for the lead.:thumbsup:
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
SET OF (4) MQ POWER GENERATORS (A55745)
SET OF (4) MQ...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55314)
2025 Wacker Neuson...
2010 INTERNATIONAL SF647 CRANE TRUCK (A55745)
2010 INTERNATIONAL...
