Using a subsoiler as a ditch digger
   / Using a subsoiler as a ditch digger #11
This what I use for trenches. It is a hyd motor turning a 26 in carbide tipped wheel. Does an outstanding job.
You could make something like this with a hyd motor, blade disk, and carbide teeth. Mount it on the bucket , 3pt or make a push/pull trencher.
I also have the subsoiler for pulling pipe.
Is that the powertrac stump grinder?
   / Using a subsoiler as a ditch digger #12
I'm pretty sure it was a close-out at Agri-Supply. They were changing to the fix/solid ones that looked like King Kutter at $50 more. I paid $95 IIRC, when I saw that it was adjustable, I had to have it.
I just looked it up on Agri-Supply and it's still listed but for $129... No photo there :(
3-Point Hitch Middlebuster - Agri Supply
   / Using a subsoiler as a ditch digger #13
Yes, it is a stump grinder/trencher from the early 90's
Thats pretty cool JJ. I think I may want/need something to bury the line while I am at it (since I found out I can).
On a different note I am thinking of building a scaled down sickle mower type contraption for pruning grapes, blackberries and raspberries (I have about 3 acres of them). I want to learn more about a Hydraulic motor that would give me the reciprcating action.
   / Using a subsoiler as a ditch digger #15
...I want to learn more about a Hydraulic motor that would give me the reciprcating action.
You've come to the right place :laughing:
I saw where agrisupply has several of them. I am gonna get one for this very reason... Thanks for the lead.:thumbsup:
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
2021 BOBCAT T870 SKID STEER (A52707)
2021 BOBCAT T870...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
74" PLATED HEAVY DUTY BOX BLADE (A57192)
74" PLATED HEAVY...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
