Using a subsoiler as a ditch digger
   / Using a subsoiler as a ditch digger #11
This what I use for trenches. It is a hyd motor turning a 26 in carbide tipped wheel. Does an outstanding job.
You could make something like this with a hyd motor, blade disk, and carbide teeth. Mount it on the bucket , 3pt or make a push/pull trencher.
I also have the subsoiler for pulling pipe.
Is that the powertrac stump grinder?
   / Using a subsoiler as a ditch digger #12
I'm pretty sure it was a close-out at Agri-Supply. They were changing to the fix/solid ones that looked like King Kutter at $50 more. I paid $95 IIRC, when I saw that it was adjustable, I had to have it.
I just looked it up on Agri-Supply and it's still listed but for $129... No photo there :(
3-Point Hitch Middlebuster - Agri Supply
   / Using a subsoiler as a ditch digger #13
Yes, it is a stump grinder/trencher from the early 90's
Thats pretty cool JJ. I think I may want/need something to bury the line while I am at it (since I found out I can).
On a different note I am thinking of building a scaled down sickle mower type contraption for pruning grapes, blackberries and raspberries (I have about 3 acres of them). I want to learn more about a Hydraulic motor that would give me the reciprcating action.
   / Using a subsoiler as a ditch digger #15
...I want to learn more about a Hydraulic motor that would give me the reciprcating action.
You've come to the right place :laughing:
I saw where agrisupply has several of them. I am gonna get one for this very reason... Thanks for the lead.:thumbsup:
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
20 DISC SANDER/GRINDER (A55745)
20 DISC...
golf cart electric (A55787)
golf cart electric...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56138)
2012 FREIGHTLINER...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
