running high gpm attachments out front?
   / running high gpm attachments out front? #3
Nice looking power pack.
Deere has something like that as does Michigan Iron and Equipment, but I dont know that either has a cooler their power pack.
Aaron Z
   / running high gpm attachments out front? #5
It's $4,500. I thought it could be used for a front mount ammbusher type mower out front or a snowblower in the future.
GACK!
$4500 for a tank, pump, short PTO, a few hydraulic doo-dads and some square tube? :confused2:
   / running high gpm attachments out front? #6
Might want to contact TBN member grsthegreat. I think he has one of those units.
   / running high gpm attachments out front? #7
We offer (2) different PTO Shaft Driven Hydraulic Power Units, 15gpm and 23gpm. Our pricing is a bit softer that what is quoted here. Our Power Packs are also PTO Shaft Driven instead of a PTO PUMP. The hydraulic pump is built into the power pack. We do not use a cooler. The reservoirs are sized at twice the hydraulic flow to control the temperature.
If you plan on using one of these units, you need to consider the size hose required to properly power a front attachment.
Do you have a link to the 23 GPM unit? That should handle an ammbusher type mower or blower on my tractor.
   / running high gpm attachments out front? #10
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Hays LT1 Tender (A56438)
Hays LT1 Tender...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2014 Grove TMS700E 60 Ton Hydraulic Truck Crane (A60460)
2014 Grove TMS700E...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2019 GALYEAN...
