Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
Oh yeah! The bay bridge. My friend's dad works for Caltrans as an engineer and has something to do with building that section. They have come a long way since it first started even though I think they are past the deadline.
Cool thing is, the Dad promised to give me and his son a tour when near completion before the grand opening! Its on my list along with a Police Ride Along with our neighbor. The City of San Francisco has some interesting police stories.
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #142
I worked on the estimate for the first phase, but retired before my company was awarded the contract. One billion, 316 million, and some change. I think they got the first 3-phases.
How awesome was that experience?
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #144
Oh God I hated working in the office, especially the main office! I'd much rather be out in the field with the guys.:cool:
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #145
Deereman! Very cool! I am glad you are liking the unit. Let me know if you get chance to post some pics. The StickWeld is a very popular model for us! With the special we ran, there will be a few more reviews up shortly!
I am hoping to get someone into a plasma cutter!
If you have another special like that I would be in a plasma :thumbsup:
What were you responsible for while working there?
Give us a call. I can see what we can do for you. I am not sure about the 40% off, but we will try to take care of you.
Simon
510-887-7090
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #149
StickWeld 250 Review
Pro's:
At the Power Output of 250 Amps DC, it is a light weight and compact unit.
Awesome Duty Cycle ratings
Dinse connectors make changing polarity and adding a lead for more reach easy.
Copper contacts on the ground clamp
Con's:
Manual could be improved
Purchased to replace my stolen stick machine. The discount made it a great opportunity to get back my stick welding capabilities. Biggest problem, as with anything, I now want more stuff for it. As in 25' and 50' work leads, 160 amp whip, 50' of 8 gauge power cord, large selection of electrodes and a modified hand truck to tote it all around.
I wanted a handle for mine so I made me one. It slides into existing slots on the front and rear covers which required no modification to the machine. Material used was 1/8"x1-1/2" flat, 1/2" pipe and 3ea 1/8" 6011 rods. The flat bar needed to be ground thinner so it would easily slide into the cover slots.
I am a Happy Camper... much more welder than I needed!
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #150
Pro's:
Con's:
Good review, glad your happy. I love my stickweld 250, I am going to burn a few more pounds of rods before I write my review.
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #151
FYI. When you go to buy those 50mm dinse fittings they're about $35.00 a piece! I suggest a cheaper way. Cut the leads that came on the machine about 18-inches to 2 feet from the male dinse fitting. Buy two female, and two male Tweco lead connectors. Should be able to buy a box of Tweco fittings cheaper than the dinse connectors. Here is a set for $13.01.
[ame=http://www.amazon.com/Tweco-SEPTLS35894251225-Weldskill-Cable-Connectors/dp/B002C0SVMA]Amazon.com: SEPTLS35894251225 - Weldskill Cable Connectors: Home Improvement[/ame]
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #152
Here is a likely stupid question. What measurment is the 50mm. 50mm is 2 inches, and nothing on them (that I can see) is 2 inches. The ones on mine are 1/2 an inch in diameter.
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #153
I come up with .5110
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #154
Well in my defence the battery in the caliper was dead, so I had to go off the scale printed on the slide. Now that I think about it, I should have just got the one with the dial...
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #155
The ones I got for the PowerArc 200, I had to cut about 1/8 inch off in length to work.
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #156
I just cut the original cable in half and spliced in a new section. Used copper crimp splices and heat shrink tubing.
Ian
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #157
Ok one thing I cant figure out about this fancy new welder is what the arc force does. Does it make the arc more focused? Does it make it dig more? I am sure it would be much easier to set it if I knew what it did. :confused:
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #158
Arc Force, When turned up, Will allow you to push a 1/8 rod through 1/2" plate without sticking or going out. Or, It can keep the stick lit when you suddenly go out of possition like when welding around a pipe or other obstruction. At least on equipment that I am familiar with and own. I have laid a rod almost flat on it's side and not lost the arc due to Arc Force being turned up. Try it..
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #159
Ok that will help. I will try messing around with the arc force as soon as I can.
/ Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #160
I have a Longevity plasma cutter that I bougt 3 or 4 years ago. I talked to Simon at length before I bought it and when I ordered it I had it in just a few days. It has performed flawless for this time I have had it. I had a problem with the gun after a couple years and was told to send it in. I boxed it up and had my wife send but she did not put Insurance on it and the mail system lost it. I call Longevity to check on it and was told they never recieved it. The person I talked to looked for it but it was never found so I told them I would have to buy a new gun. I was put on hold and when he returned he asked for my address and informed me that they were sending me one at no chaarge. I almost fell over. I thought what kind of company nowdays has service like that. I would buy from them again in the future if the need ever arises.
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2022 John Deere R4023 (A60462)
2022 John Deere...
DEUTZ MARATHON...
DigiTrak Aurora AF8 Horizontal Drilling Display Set (A59228)
DigiTrak Aurora...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
