Comparison B26 vs B series tlb
   / B26 vs B series tlb #21
I have a b26 and it handles a 5 brush mower fine and in the woods on trails I like it better than our m5400 as just easier handle around trees. As for loader and hoe seem real strong for a machine that is that size. If you post were its at I would be in line lookin as that seems real cheap.
   / B26 vs B series tlb #22
Rhino,
As far as any weak spots/flaws in the B26's design,i dont know of any.What i would look for would be things like cracked welds,dented or twisted loader arms,damaged hydraulic lines,stuff like that.Check the tires for
wear....with low hours like that it should'nt be much.Also check for smooth operation of the hyd. cylinders,(it is possible to bend the rams with abuse).
Underneath the tractor dead center there is a big hyd. oil resevoir.
Check to see if its dented or beat up.I'd also check for oil in the antifreeze
or antifreeze in the oil.If it has freshly changed / really clean oil that might be tough.Actually,with as low as hours as its supposed to have,it really should almost look like new.Take a couple of your buddies along to help check it out.
One of them might see something you dont.
As far as the B26 being a good machine,i love mine.I have'nt had a bit of trouble with it yet,and although i dont abuse it,i do use it.
Also....just as a referance
In October of 2007,I paid $28,500 for mine.This did not include tax.
It did include the heavy duty removable 60" front bucket with the bolt on cutting edge,18" Q.A. hoe bucket,Hydraulic thumb on hoe,horn,back-up alarm,front and rear worklights,and toolbox.I know they have gone up in price since so this is just a referance.
Just dont jump into it and get burnt.But if you do get it i hope it all works out OK.............Good Luck.................digger2
Quick update... The person I needed to speak with wasn't around until today. We are working on better photos as I type this. It helps that they are also a Kubota dealer and stated have all maintainance records. They are also agreeing to have their service department give it a once over and if I have any concerns address them at that time. It has lived outside since 2008 but didn't appear too bad as far as rust, etc. Further pictures should help verify that. It does have the 3 pt arms, drawbar, manuals, 18" bucket (I believe it is the quick attach they are unsure). Looking into the aux hydraulics for the backhoe. I assume that if the boom has hydraulic hookups on the exterior that this means it does have them? They will be sending pics of the bh platform so I will be able to see if the foot control is there. It hasn't been out since Sept 2011 and that was by the employee I spoke with. He stated it has been started periodically and winterized. TLB's haven't been moving around by me so it should leave room to move down in price.:thumbsup:
   / B26 vs B series tlb #25
Rhino,
I'm a little late to the party, but for a lot of BH work the B26 is definitely the way to go.
Being a Kubota dealer, I would tell them to throw the thumb into the purchase, won't be able to negotiate down as much, but the thumb is a very worthy add on. Even if you just get a mechanical and not the hydraulic thumb, though the hydraulic is 10 times better than the mechanical and the mechanical is 30 times better than no thumb.
If all checks out, I think it's a better purchase than a standard B series.
Good luck!
Well, I made the 2 plus hr drive to take a look at it and messed with it for about 40 minutes. Alot of things I liked and several that had me concerned. All the fluids had just been changed so that didn't help. I didn't see any signs of leaks and all cylinders looked good. The backhoe didn't seem to have much use and looked almost new. They charged extra for rental of the backhoe so mainly frontend loader work. The 3 pt arms were stored on the tractor and the pto didn't appear to ever been used. She ran well no smoke other than the startup. Nowhere to dig but the backhoe operated smoothly as did the frontend loader. The stabilizers at idle (1100rpm) easily lifted the backend with filled tires:D (calcium Cholride:(). Nothing seemed bent as far as loader, etc. I did like the skid plates under the tractor and protecting the tierods. Now for the areas that concerned me. It has been sitting outside for 4 years in sun and snow. The orange paint was very faded. The good part of that was the paint job looked sound no rust or bubbling of paint.. It hasn't been used very much and just sitting so most controls were very stiff. It was very difficult to switch into 4wd and back. The loader lock must of never been used for nobody could move it into the lock position(looked rusted). FYI, I had the employees double check these issues so it wasn't operator error:laughing:The backup alarm and horn had been disabled (wires cut). The parking brake wasn't locking (probably adjustment needed). Dent in hood and several rust spots (looks like a heavy rock hit it) metal hood not very thick. Missing locking pin for backhoe (transport lock). The other big issue were the precutouts(holes) on the dash for items like the throttle, cruise control(doesn't have) and was missing a cap on leftside of dash panel exposing the wiring. The problem being that snow rain had entered these areas and you could see rust, etc. I believe these areas will be corrected but my concern is with the lack of use and the elements rusting linkages, springs, wiring, etc. I still need to speak to "the man" who makes the calls and see what will be addressed, price, etc. I did get there rather late. FYI, the work lights are great. I did attach a few pics to show some of the areas I saw snow enter. Time to ponder.
   / B26 vs B series tlb #27
Still looks like a deal to me. Gotta expect to put a little TLC into a former rental unit. It looks a hundred times better than most rentals I've seen (and should considering the hours). I'd still be buying it if I were you. ;)
   / B26 vs B series tlb #28
Looks in really good shape for a rental unit. As far as the missing covers, as a Kubota dealer note your concern with them, have them replace missing covers after inspecting for possible corroded wiring / connections / cables. If you were to have problems down the road you'd have a record of it. When it comes to the paint and dented hood, that's something I look for in a second hand machine as it detracts from the price but is easy and relatively inexpensive to repair. If it's sound mechanically and works well, I'd go for it.
   / B26 vs B series tlb #29
I'm in agreement with what's been said. Thing looks real good for a rental. Only very minor problems. If it were me, the deal would still be on.
   / B26 vs B series tlb #30
I remember looking at an older vehicle once that looked really clean and well maintained but had several little things that needed work. I hemmed and hawed, and meanwhile someone else recognized the value and bought the silly thing. Lesson learned.
Due diligence is good. If you can inspect your areas of concern to your satisfaction and have an overall good "feel" for the machine, don't lose sight of the forest for the trees. I've looked at enough stuff that I generally get a feel for things based on level of deferred maintenance, appearance of abuse, etc. When I override that gut feel due to thinking I'm getting a great deal, that's where I screw up. What's your gut tell you when you look at the machine? Not trying to preach, but I'd hate to see you miss out on what seems to be a very attractive price on what seems to be a great TLB.
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
Hercules Rustic Gun Cabinet Holds 20 Guns (A57454)
Hercules Rustic...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
Rooster Weathervane (A55853)
Rooster...
Blue Diamond 103709 (A53317)
Blue Diamond...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
