Trailer big enough for 50HP tractor? Quick sanity check
/ Trailer big enough for 50HP tractor? Quick sanity check #21
That trailer would haul a 90 HP cab tractor and a big round baler with room to spare.......
No one needs a trailer designed to haul big tractors, backhoes, or even a small dozer to limp around a 50HP tractor a few times per year.
Unless DOT stops you for not having proper brakes. Not if a car or kid blows a stopsign or driveway and you can't stop because you don't have brakes. Uncontrollable sway due to overloaded tires or improperly biased load weight. There are a few good reasons to have a safe trailer besides reducing the risk of you killing someone or yourself. I have had friends drive trailers that had inadequate brakes that regretted that move. No dead friends but underwear changes required. In my state you have to have brakes on a trailer over 2,000 pounds.
A 40 horsepower tractor may not mean much. A 40 hp tractor could weigh 3,500 pounds and another could weigh 5,800 pounds without implements. That DK55 weighs about 5,000 before implements. You could add another ton in implements depending on what you are carrying.
My little JD870 with a loader and brush cutter is a huge pain to load on a 16 foot trailer tag along. Not so bad when the pulverizer is attached. For me it is not a question of weight as much as just plain fitting and getting bias correct.
/ Trailer big enough for 50HP tractor? Quick sanity check #22
Are you kidding? He needs a Kenworth and a lowboy....:thumbsup:
I have an 18' 10K trailer which means I can load it up to 7,500 pounds. You could squeeze a DK55 on it as long as you don't want to bring any implements. Mine was full with a ck27 and 5' brush hog.
I am fortunate that i have a 28' gooseneck when I want to move big/ heavy stuff. Last year you could get a 24' Delta for around $4500. Not cheap but not bad either. I use the GN a lot but it is big.
/ Trailer big enough for 50HP tractor? Quick sanity check #23
What would that big two axle trailer with duals cost? $10K+?
Thing probably weighs more than the tractor...... weekend warriors simply don't need 100K tow rigs.
/ Trailer big enough for 50HP tractor? Quick sanity check #24
IronHog - I think that was sarcasm :)
BTW, if you want to see what my setup looks like, it's in my avatar. The bucket is at the rear end of the trailer. Balances good and pulls very nicely, even at freeway speeds. More length would be great as 16' is short for this, but for my current needs, it works.
/ Trailer big enough for 50HP tractor? Quick sanity check #25
Your trailer looks like something I we would use to move a small tractor.
I grew up on a full time cattle farm.... according to TBN we should have died multiple fiery deaths with the trailers we moved/move big loads on......
/ Trailer big enough for 50HP tractor? Quick sanity check #26
I know what you mean. Some of these guys would have a stroke if they knew the gross weight that I routinely load my 27' dual tandem gooseneck to and pull it behind a 3/4 ton pickup.
/ Trailer big enough for 50HP tractor? Quick sanity check #27
I have a 50 hp Farmtrac 60 with loaded 14.9-28" ag tires/fel and a 6' mower that rides on a new 10k GVWR bumper pull 18' dovetail with tandam 5200 lbs axles/10 ply rated tires. The trailer weighs 2460 lbs unladin.
With 1000-1050 lbs on the truck the load on the trailers axles is around 9500 lbs depending on the tractors loaction.
The bucket sits on the trailers deck and the mowers tail wheel hangs over about 24". In my state legal overhang is 2/3 of the distance from the aft trailer axle to the rear most part of the trailer.
I've pulled out to 250 miles a few times working on a lease. No issues
Previous trailer was a flat deck 16' 7k GVWR (two 3500 lb axles). It was severally overloaded. After one 75 mile trip I sold it and got the correct trailer. Much better towing especially with 10400 lbs of trailer brakes vs 7000 lbs on the old trailer.
I should have included a picture of the trailer w/ my B7610 on it.
As you can see the B7610 leaves it a lot of room.
/ Trailer big enough for 50HP tractor? Quick sanity check #29
You need this rig to safely move a 50 hp tractor :laughing::laughing:
/ Trailer big enough for 50HP tractor? Quick sanity check #30
Eh, I see where people are coming from. Many folks on here are novices (like myself, frankly), so it is better to push people towards the correct equipment the first time, if they have the choice. That means one less thing for a newbie to screw up. With my setup, if you load it the other way around (pointing forward) there is nowhere near enough tongue weight. If you don't know that, you could get into trouble. With an 18' or even better a 20' trailer, you would have room to adjust to get it right and that risk would go away. I wish I had gotten a longer one, but I knew nothing when I did it. Now that I know how it behaves, it works fine for my needs.
Like the OP - Unless he is going to be hauling it a ton, he should be fine as is, if he has any level of experience (like it appears he does). But if something changes like he is doing it all the time or wants to haul with a 6-7' bushhog on the 3pt, then he probably needs to upsize. He's fine on weight capacity, just needs more length.
/ Trailer big enough for 50HP tractor? Quick sanity check #31
Oh man, we'd put 120 bales of square hay on that nice trailer and pull it all over..... probably behind a 1/2 ton pickup.
That is a good trailer...... and your 1 ton pickup will let you get away with being a little forward if you need to be.....
/ Trailer big enough for 50HP tractor? Quick sanity check #32
I remember when I was a kid the only pickup we had that would pull the gooseneck was a '74 Dodge Power Wagon....... 4 wheel drum brakes and no connector for the trailer brakes. Thing would pull like a modern diesel but braking was poor and largely dependent on how much mud was caked in the drums.....
Point is safe hauling is more about proper loading and driving than spending thousand on the baddest overkill trailer on the net.......... just don't be like the idiot tailgating and trying to pass on a hill with his 34' fifth wheel and you'll probably be fine.
/ Trailer big enough for 50HP tractor? Quick sanity check #33
Hi all,
Interesting thread as I am trying to figure out if I can fit a TN70D with a 32LA FEL and a Rhino TS12 flex wing mower on my existing trailer. The trailer is a 22' utility goose-neck with a 14K gross wt. A notation on the trailer says not to load more than 10K on the trailer.
I think the tractor/FEL/mower combination will weigh about 9800lbs (operating weight). The overall length of the tractor/mower combination is 21'6-1/4" from the front of the tractor to the rear axle on the mower (I will run the loader bucket up over the trailer neck).
If I add a 2' dovetail to the rear of the trailer, I think I can load and unload the tractor/mower without ramps. The older I get the less I like ramps!
My truck is a '06 Dodge Ram D3500 which I regularly use to pull this trailer at gross weight up and down the interstates (non commercial). I do chain it down according to DOT specs just for safety's sake.
Hope this is relevant, not trying to hijack this thread
Tim
/ Trailer big enough for 50HP tractor? Quick sanity check #34
So I probably shouldn't tell people that I have a 16' triaxle beaver tail that I load my Case 580k on to haul it around.
/ Trailer big enough for 50HP tractor? Quick sanity check #35
.......I'd put that 50HP tractor (with no implements) behind my 1/2 ton on a no brake 16 foot utility trailer and haul it anywhere I wanted to go on a flat, two lane highway.
I'm sure you would.
And I don't mean that as a compliment...
Definitely NOT hijacking, very pertinent.
Hi all,
Just because it fits, doesn't mean it's a good idea. ;)
Personally, I don't want the FEL sticking over the tongue. Makes the load unstable, and you can seriously mess up your tailgate! :eek:
Personally I feel it's about the same as mounting a toolbox over the tongue. Just make sure the load is properly balanced and the tongue weight is right for the load. And have a WD hitch.
Tim
I like ramps, they make my life easier.
/ Trailer big enough for 50HP tractor? Quick sanity check #37
I'm sure you would.
Best way to go bankrupt is to waste all your money on trucks, trailers, and other toys you really don't need..... esp on a real life farm.
/ Trailer big enough for 50HP tractor? Quick sanity check #38
Yesterday I was setting the ramps to unload my skid loader from my 6X10 10K dump trailer when I dropped one of the ramps on my left big toe!! I hate ramps.
I tried loading my TN70D with a 7' 3pt shredder on the goose neck trailer a few times and was semi sucessful. The trailer deck was about 24" above grade so I had to put the tractor in 4WD to climb it. That was okay except I knocked a couple of tire lugs loose on the back tires in the process. I was thinking of installing a 3' dovetail where the end of the dovetail was 12" above grade. That puts the dovetail angle at about 30 degrees. I should be able to climb that without any trouble. On the 12' batwing shredder, the back shredder tires would ride on the dovetail. If I have trouble with them dragging, I could hinge them at the back of the trailer and raise and lower them manually as needed. I would need to come up with a lever and latch system (pat. pending) to make this work.
Tim
/ Trailer big enough for 50HP tractor? Quick sanity check #39
Oh please. "Real life farm"? Surely you jest! :laughing: :laughing: :laughing:
It's plain to see you are just an accident waiting to happen, the only question is when and it's a true wonder you haven't caused many already. Wait until you do and get sued for everything you own...then you can talk about bankruptcy.
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61306)
2020 Takeuchi...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
TPL MECHANICS BODY LUBE SKID (A60430)
TPL MECHANICS BODY...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2006 CATERPILLAR 420D IT BACKHOE (A60429)
2006 CATERPILLAR...
