65 Ford 2000 3 Cylinder
   / 65 Ford 2000 3 Cylinder #31
i have never seen an early model with a dry air cleaner that was orginal but i could very well be wrong just never seen one in my area
I think part of the reason you and I have discussions like this is that tractors (of any brand) were spec'ed out differently in the South than the Northeast or even the Corn Belt. A couple examples would be 2WD versions of Ford and New Holland compact tractors which are practically nonexistent in the Northeast, IH tractors built as TA delete tractors far, far more common in the South. And Cabbed tractors in general, which seem to not be as popular as soon in the South as in the North.
   / 65 Ford 2000 3 Cylinder #32
but im not like most i wont argue with you because i believe you about these fords because you should no and just because i haven't seen it doesn't meen it aint out there just like most people have never seen a ford doe
but yea i have seen more ih's down here with out a ta but when we get them out of the north 90% of them have one
Re: 75 Ford 2000 3 Cylinder
Got the canopy on yesterday. That was a pain by myself out in the middle of a field but I figured out to get it up on top of the ROPS and hold it while I got a couple bolts in. I have a pic and will post it later.
The battery that was in the tractor I knew up front was not the correct one (too small) but it started up fine that day a number of times. After sitting a week yesterday I had some trouble starting and I also got it flooded so I let it set for a bit and then got it started up OK, but I think have the problem from the beginning yesterday was that the battery didn't have enough umph to spin the starter fast enough, was always turning slow even the first time I cranked it over. Took battery to friends place and load tested it, sure enough its weak. We put it on charge and I took it back and it started OK (this is after I flooded it and let it set). So I went off looking for a new battery. Well on a Saturday afternoon all the parts houses are closed so no help there. While I was near civilization I tried surfing the web on my phone to find the correct battery size but was coming up short. Stopped at TSC and there battery application chart was worthless unless you had the original battery or knew the original group size. I didn't have anything with me in the field to measure the tray size with so wasn't sure what would fit. Tried one battery (don't remember group size right now) but it was too tall. Took it back and thought about the F-4DLT but that was too long for my tray so couldn't use that either. found some conflicting information on this question raised on another forum where it was debated if the 4DLT or a 17TF. No size 17TF at TSC so went with the biggest (highest CCA) low profile battery I could find on the shelf. I didn't get back to put it in yesterday, maybe today if chores don't take all day.
Working on it is gonna be tough as I have only a small shed big enough to put the tractor in and lock it up and I had to make room in there to squeeze it in, so no working room in bad weather or to store or spread out anything I'm working on. No electricity within 500 feet so if I need power I'll have to drag a generator over from the house or use cordless tools (drill, impact driver, etc.) which I have.
I changed both air filters with new ones I had picked up at the NH dealer the other day. $86 for the pair of them, yikes! I had noticed when I was looking the tractor over the day of purchase that the gas cap seal was deteriorated and while getting the air filters I asked if they had on in stock and how much. No, don't have one for a gasser but can order it...$68...for a stinking gas cap that has nothing special about it? They got to be kidding. I look up a STANT gas cap from my local NAPA dealer and its $5.99, and chromed to boot.
I looked over the condition of the plugs wires, cap/rotor/points. they are not in such bad shape so maybe I can get by for right now with them. No signs of arcing on the cap and the terminals are all clean, no corrosion at the plug wire connections and nothing on the inside of the cap, and no pitting on the points. Haven't checked timing or point gap yet, didn't have those tools with me.
That will be the other inconvenient part of working on this, all my tools are at another location 8 miles away, so everything will be like doing a field repair w/o the benefits of a shop for such things as a concrete floor to work on (if I need use a jack its safer on a stable surface), torch, welder, air compressor, work bench w/vise, etc.
If I had a flat bed trailer I would drag it over to the shop when I wanted to work on it but I don't. The trailer I used to bring it home was not mine. Between the Bobcat and now this tractor its getting to where I almost need my own trailer. The Bobcat will fit in the dump trailer but the tractor won't. I'd prefer and I'm looking around to see what's out there and also pricing new flat bed and tilt bed trailers. There are a couple auctions coming up soon so maybe I can find something there. Maybe I'll get lucky and find a trailer and a mower and a box blade all at the same auction. :)
Today I found some time to clean the tractor up a bit. I washed it from stem to stern and it looks much better. I also got the new battery in and it starts much better. I wanted to warm everything up after the washing to dry up any water so I drive around for about 15 minutes to get it into operating temperature range. The temp gauge showed it was above mid-scale but not in the red.
I tried to watch for the stat opening up but couldn't see any indication on the gauge. Once the temp got to mid-scale I drove for another 5 to 8 minutes and it never went higher, but I was not working it at all just driving around. Still it did not overheat so I am reasonably sure the stat is working if there's one in there that is. The t-stat housing look like its been off recently so its been changed or removed. Easiest way to tell I can think of is to take the radiator cap off when cold and start it up. If there is circulation from the start then no stat because water is being pumped to the radiator. If there was a stat then initially it would be closed and the system would be in bypass and sending the coolant back to the block to warm it up faster not the radiator. Either that or I will take a reading with my IR temp gauge at the t-stat housing.
Sorry for the fuzzy pics. Must have left the focus setting in macro when I took a closeup of the data plate the other day. :(
The first pic is the only sheet metal damage I can find ither than a couple scrapes on the bottom of the front grill. I think if I take the fender off I can do a decent job of banging this out. Too bad the paint is gone.
In contrast here is a photo from yesterday.
It may not look it but its a big improvement over yesterday. Getting all the dirt off the wheels, canopy and sheet metal took about 45 minutes of scrubbing by hand with a brush.
   / 65 Ford 2000 3 Cylinder #35
What is the leaver on the left side behind the clutch petal?
   / 65 Ford 2000 3 Cylinder #37
The reason I asked is because I just got a ford 420 backhoe and it has it on there also it moves in three positions but dosent change anything? So would that be a 2 speed pro on that tractor?
Don't know, you'll need to wait for a response from one of the gang on here that live and breathe these old Fords, I'm a newbie just having bought this tractor 2 weeks ago.
   / 65 Ford 2000 3 Cylinder #39
i'm not up on the industrials.. might ask rickB.. maybee ultradog.. he's way more familiar with the 3 cyl jobs than I am.
I'm a 65 and down guy mostly. have some 65+ machine.. but not as many as 65 and down.. :)
   / 65 Ford 2000 3 Cylinder #40
there was no two speed pto on that model tractor
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
CATERPILLAR 315FL CR EXCAVATOR (A51242)
CATERPILLAR 315FL...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
