FMI-How many hours or miles on Mobil 1 Syn.
   / FMI-How many hours or miles on Mobil 1 Syn.
Mrkdmar - Sorry to hear of your issue with the Legacy. It would seem unlikely it was the fault of the oil. I am not familar with the Legacy, gas or diesel? I have used synthetic ATF and gear oil over the years with no issues, of course I had no issues using dino products either. The big advantage to me with synthetics is the longer service life. In equipment that I do not run as much I tend to go with regular dino stuff.
I used the Mobil 1 Synthetic Atf in my final drive on the Toyota Camry and besides protecting the gears the mileage per gallon went up . I felt good about it, but the Highlander uses special ATf fluid for electric shift..
   / FMI-How many hours or miles on Mobil 1 Syn. #22
Back when I used to do a lot of field service work all over I would average about 40,000 miles on my car per year. At the time I drove a Pontiac Bonneville 3800. I changed the oil every 10,000 miles, used a Purolator Pure-One filter and Mobil-One 10w30 full synthetic. Car currently is retired and sitting in the junker's row behind my barn with 287,000 on the clock. Still runs great, used less than a quart of oil in 10K miles, oil pressure was fine- 2/3 gauge cruising at 2000 rpms and 1/4 gauge at hot idle. What finally killed that car was rust. All the steel lines had been replaced piecemeal and it started popping rear brake lines again. This time I could see rust at the suspension mounts and door hinge pillars. Not worth fixing.
My 1989 Jeep Cherokee Laredo has 300,000 miles on it, and I change the oil every 5000 miles with regular "Whatever is on sale" 10w40 oil and filters, usually AutoZone package deals. It uses a quart every 3000 miles or so depending on how hard I am running it, leaked and burnt.
My 2003 Toyota Tundra V-8 I use only Castrol GTX 5w30 and whatever oil filters I have in stock that fit I got on sale at AutoZone. 7500 mile change intervals. At 7500 miles it usually is down less than half a quart. Motor is tight and clean inside.
   / FMI-How many hours or miles on Mobil 1 Syn. #23
3k. I use to do the extended oil changes on my 2003 f-350 diesel with amsoil synthetic. I had the oil sent in for anylisis ay 7k and the TBN had dropped like a rock. so I determined that the expensive oil was a sham. I change now at 3k and let ford
do the change.
   / FMI-How many hours or miles on Mobil 1 Syn. #24
i hear all these amsoil freaks do OA at 5k and say they get 30k out of oil and it was still good.:confused2:
   / FMI-How many hours or miles on Mobil 1 Syn. #25
Yeah, I hear the same thing. I sent my oil in to blackstone labs and at 7k it wasnt good. so, as I stated before. Its 3k oil changes for me. Ford only charges 90 bucks and I dont have to bother with disposal.
   / FMI-How many hours or miles on Mobil 1 Syn. #26
Mobil 1 Turbo Diesel Truck in my car changed at every 10-12k....others with same car/oil have done samples and UOA shows no change until about 15k miles.
   / FMI-How many hours or miles on Mobil 1 Syn. #27
Volvo V90 (straight 6, RWD) and Dodge Caravan SE (V6, FWD). Both get oil changes when the snow tires go on in Oct/Nov and if I am feeling up to it, a filter change when the snow tires come off in April.
~10k miles per year on both cars running M1 5W-30 Synthetic and Mann filters (both take the same filter so I buy them by the case from FCP Groton).
Had the head on my Volvo redone last winter (t-belt idler bearing let go and bent a bunch of valves) and the guy who did the work insisted on conventional oil for the first 2-3k miles. Just changed it back to synthetic and noticed that the oil pressure light goes out faster on startup and there is less valvetrain noise on startup.
Aaron Z
   / FMI-How many hours or miles on Mobil 1 Syn. #28
Mobil 1 Turbo Diesel Truck in my car changed at every 10-12k....others with same car/oil have done samples and UOA shows no change until about 15k miles.[/QUOT
Whats the TBN at when you get the test results? I've never heard of an oil that resists breakdown.
   / FMI-How many hours or miles on Mobil 1 Syn. #29
He may be referring to increased levels of wear metals rather than other aspects of the oil ....
But since you raised the issue, what exactly is "TBN dropping like rock" ?
I mean, I assume that Blackstone did provide a report with a TBN number didn't they ?
What was it ?
What was the TBN number of the oil before use ? (VOA)
Did you also have a TAN done ?
What was Blackstone's recommendation on the oil at 7K ?
The premise of your statement seems somewhat odd .... TBN does drop .... it's supposed to .... that's an indication that it's doing job .....
   / FMI-How many hours or miles on Mobil 1 Syn. #30
What was it ?
the oil started out at 14 TBN (Total base number) and dropped to 6 at 7000 miles. They recommended changing it. this has been several years ago and I dont have the test sheets or the truck any longer.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
Caterpillar 906M (A53317)
Caterpillar 906M...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
iDrive TDS-2010H...
