FMI-How many hours or miles on Mobil 1 Syn.
   / FMI-How many hours or miles on Mobil 1 Syn.
Mrkdmar - Sorry to hear of your issue with the Legacy. It would seem unlikely it was the fault of the oil. I am not familar with the Legacy, gas or diesel? I have used synthetic ATF and gear oil over the years with no issues, of course I had no issues using dino products either. The big advantage to me with synthetics is the longer service life. In equipment that I do not run as much I tend to go with regular dino stuff.
I used the Mobil 1 Synthetic Atf in my final drive on the Toyota Camry and besides protecting the gears the mileage per gallon went up . I felt good about it, but the Highlander uses special ATf fluid for electric shift..
   / FMI-How many hours or miles on Mobil 1 Syn. #22
Back when I used to do a lot of field service work all over I would average about 40,000 miles on my car per year. At the time I drove a Pontiac Bonneville 3800. I changed the oil every 10,000 miles, used a Purolator Pure-One filter and Mobil-One 10w30 full synthetic. Car currently is retired and sitting in the junker's row behind my barn with 287,000 on the clock. Still runs great, used less than a quart of oil in 10K miles, oil pressure was fine- 2/3 gauge cruising at 2000 rpms and 1/4 gauge at hot idle. What finally killed that car was rust. All the steel lines had been replaced piecemeal and it started popping rear brake lines again. This time I could see rust at the suspension mounts and door hinge pillars. Not worth fixing.
My 1989 Jeep Cherokee Laredo has 300,000 miles on it, and I change the oil every 5000 miles with regular "Whatever is on sale" 10w40 oil and filters, usually AutoZone package deals. It uses a quart every 3000 miles or so depending on how hard I am running it, leaked and burnt.
My 2003 Toyota Tundra V-8 I use only Castrol GTX 5w30 and whatever oil filters I have in stock that fit I got on sale at AutoZone. 7500 mile change intervals. At 7500 miles it usually is down less than half a quart. Motor is tight and clean inside.
   / FMI-How many hours or miles on Mobil 1 Syn. #23
3k. I use to do the extended oil changes on my 2003 f-350 diesel with amsoil synthetic. I had the oil sent in for anylisis ay 7k and the TBN had dropped like a rock. so I determined that the expensive oil was a sham. I change now at 3k and let ford
do the change.
   / FMI-How many hours or miles on Mobil 1 Syn. #24
i hear all these amsoil freaks do OA at 5k and say they get 30k out of oil and it was still good.:confused2:
   / FMI-How many hours or miles on Mobil 1 Syn. #25
Yeah, I hear the same thing. I sent my oil in to blackstone labs and at 7k it wasnt good. so, as I stated before. Its 3k oil changes for me. Ford only charges 90 bucks and I dont have to bother with disposal.
   / FMI-How many hours or miles on Mobil 1 Syn. #26
Mobil 1 Turbo Diesel Truck in my car changed at every 10-12k....others with same car/oil have done samples and UOA shows no change until about 15k miles.
   / FMI-How many hours or miles on Mobil 1 Syn. #27
Volvo V90 (straight 6, RWD) and Dodge Caravan SE (V6, FWD). Both get oil changes when the snow tires go on in Oct/Nov and if I am feeling up to it, a filter change when the snow tires come off in April.
~10k miles per year on both cars running M1 5W-30 Synthetic and Mann filters (both take the same filter so I buy them by the case from FCP Groton).
Had the head on my Volvo redone last winter (t-belt idler bearing let go and bent a bunch of valves) and the guy who did the work insisted on conventional oil for the first 2-3k miles. Just changed it back to synthetic and noticed that the oil pressure light goes out faster on startup and there is less valvetrain noise on startup.
Aaron Z
   / FMI-How many hours or miles on Mobil 1 Syn. #28
Mobil 1 Turbo Diesel Truck in my car changed at every 10-12k....others with same car/oil have done samples and UOA shows no change until about 15k miles.[/QUOT
Whats the TBN at when you get the test results? I've never heard of an oil that resists breakdown.
   / FMI-How many hours or miles on Mobil 1 Syn. #29
He may be referring to increased levels of wear metals rather than other aspects of the oil ....
But since you raised the issue, what exactly is "TBN dropping like rock" ?
I mean, I assume that Blackstone did provide a report with a TBN number didn't they ?
What was it ?
What was the TBN number of the oil before use ? (VOA)
Did you also have a TAN done ?
What was Blackstone's recommendation on the oil at 7K ?
The premise of your statement seems somewhat odd .... TBN does drop .... it's supposed to .... that's an indication that it's doing job .....
   / FMI-How many hours or miles on Mobil 1 Syn. #30
What was it ?
the oil started out at 14 TBN (Total base number) and dropped to 6 at 7000 miles. They recommended changing it. this has been several years ago and I dont have the test sheets or the truck any longer.
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
