Ford8n Antifreeze
   / Ford8n Antifreeze #41
With this new site i seem to be seeing WAY WAY more double posts? Soundguy, any idea what happened to double post? Not picking at you, i have seen many different folks since the up date do it?
   / Ford8n Antifreeze #42
have no idea why. But may have something to do with when the dialog boxes pop up asking you if you want to navigate away from the site when posting a message. if you hit no, your message appears not to post. if you hit yes, it relaods the page with the psoted message appearing normal.
seems like one or the other is double the posting.. normally tbn used to 'catch' dupe posts. guess not now?
   / Ford8n Antifreeze
so a 5 15 tire would fit for sure? i can buy a pair for 114 at tsc
   / Ford8n Antifreeze #44
unless it is a very odd / wide rim, .. there are not many options for tractor tires in 15" 5-15 is the usual stocked one.
measure the rim width.. see what the tire reccomends for mounting width. as long as the rim is not too narrow or wide..e tc..
   / Ford8n Antifreeze
i cant mesure the rim the tires are on it along with it on the tractor now i reakon they will fit it
   / Ford8n Antifreeze #46
Try taking the rim off and going to a tire shop. They will find one for you.
   / Ford8n Antifreeze #47
a big set of OD calipers can measure it for ya.. but yeah.. a tire shop will know.
ps.. check the tires on it.. most say what rim size they are made to fit..
   / Ford8n Antifreeze #48
Was gonna say the same thing. Usually they say like 15x5 or something on them somewhere.
   / Ford8n Antifreeze #49
Im sure they will fit, unless there like super wide truck rims or something.
   / Ford8n Antifreeze #50
some will say rim width as well.. for instance.. for rear rims you commonly see in 10-11-12 width sizes.. etc..
46006 (A51694)
46006 (A51694)
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2016 Ram 5500 4x4 Altec AT37G 37ft Bucket Truck (A50323)
2016 Ram 5500 4x4...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
