Disposing 50 yards trash filled dirt
   / Disposing 50 yards trash filled dirt #21
Try calling a local fencing company and ask if they have any used/salvage fencing. I was pricing some new heavy chain link for an arena drag and asked about used; they said they had lots, so a big saving.
BOB
   / Disposing 50 yards trash filled dirt #22
That's been one of my concerns. I started wearing a dust mask while I was loosening and piling the dirt. How do you tell if a shingle has asbestos? Do you break one and see if its stringy?
Easiest field test, use a cigarette lighter; if it burns - no asbestos
   / Disposing 50 yards trash filled dirt #23
WRONG! asbestos only way to find out, is by a lab. with correct equipment normally a microscope is required. or something much more costly!
Don't mean to be negative, but if the shingles are composite you should check for the presence of asbestos. Laying on the ground undisturbed, the shingles should not be a problem. Start messing with them and the asbestos becomes friable, you have problems.
adding to greasemonkeyok
breaking the shingles / tearing the shingles, can cause asbestos to come out of a shingle. errr they become friable.
a generic dusk mask you can get at local hardware stores and like. do not even filter low enough to deal with any sort of asbestos, let alone many other things.
I did some reading and they've done testing at recyclers and out of thousands of asphalt shingle samples tested they might find one or two samples containing less than 1% asbestos. It wasn't widely or heavily used in asphalt shingles.
   / Disposing 50 yards trash filled dirt #25
We couldn't find a reliable method of doing it yourself, and paid a local environmental lab to test some ceiling tiles we thought were most likely asbestos. Turned out, the tiles were just fiberglass so MNBobcat may have a point. Find a local environmental lab to give you a report, or there are some on the web such as:
Asbestos Testing Lab | Asbestos Testing Kit | EMSL Analytical Inc
The above is just an ad I found on Google, and I know nothing about that facility.
Think about the fact that the lab is going to ask you for the address of where the sample was taken.
   / Disposing 50 yards trash filled dirt #26
A Dumpster rental is what you need. Sort through what you can and dump the rest. 30 yard rolloff is $450 here.
   / Disposing 50 yards trash filled dirt #27
Check with the Dumpster supplier first. Generally they limit the fill with dirt to about 1 foot or so as it is too heavy to lift and transport. Thirty CY of dirt would be over 80,000# not counting the bin or truck.
   / Disposing 50 yards trash filled dirt #28
Around here you'd get three tons allowance with that $450 dumpster and $100 for each additional ton. And no dirt or concrete, that has to go in a special dumpster.
Hi Guys,
As I got into that pile further I found what looked like fiberglass cloth and it had spread all over the ground from working the pile. When you crushed it in your fingers, it turned to white dust. If you picked it up, white powdery like dust filled the air.
Needless to say, that made me rather concerned. It wouldn't burn either. So I got out some brand new fiberglass cloth I have and tested it and it wouldn't burn either. That was good news because then it was possible it was fiberglass backing from the shingles and not asbestos. The thing is...I've never seen fiberglass powder like that when it gets old.
I took 2 samples to a lab today ($50) and it came back negative on asbestos. Was well worth the piece of mind it gave me.
But it goes to show that you need to be cognizant of what you could be digging up. I learned a valuable lesson and am very appreciative that you guys pointed out that there could be some nasty stuff in there. I've been wearing a cartridge respirator when I work. It helps keep the dirt/dust out of my lungs, too.
I'd need 10 dumpsters for what I had on hand. No, can't do the dumpster option. But I did find someone who wanted 30 yards of it for fill so now I'm down to about a half a pile!
   / Disposing 50 yards trash filled dirt #30
Our dumpster company lets us put in what ever we want (other than haz-mat and tires). There is a flat rate for a xx yard dumpster with a weight of up to x tons. Every ton over the limit is $70, IIRC.
Here are pics of our last load:
http://www.tractorbynet.com/forums/projects/244309-dumpster-cleanup.html
That was a 20 yard container that weighed in at 10 tons. :confused2:
John Deere 4510 (A53317)
John Deere 4510...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
INOP Four Wheeler (A57453)
INOP Four Wheeler...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
Kubota Utility Cart (A59228)
Kubota Utility...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
