Moving firewood palette with BX, bolt on forks
   / Moving firewood palette with BX, bolt on forks #11
niemeyjt,
I don't see prices for the bags. Do you know the different prices for the various sizes and colors?
   / Moving firewood palette with BX, bolt on forks #12
You need to call them for full pricing- I paid GBP 165 including transport and VAT (Sales Tax) for 50 of the smaller ones in Feb 2010 - the base price was GBP 2.50 which seemed to be in line with what Apache were asking (see below). I bought it from their UK operation not their NA one.
I came to them in a round about way - I originally wanted Apache Forest Products Inc., but Apache pointed me to Japa in Finland who pointed me to these people in UK.
J
   / Moving firewood palette with BX, bolt on forks #13
Thank-you
   / Moving firewood palette with BX, bolt on forks #14
Thanks guys. Seems like its going to be more work than its worth to stack 8 cord on pallets. If I can only stack a couple tier high Im going to need a TON of pallets lol. The whole reason I considered this was so I could stack vertical to save space, with ease of moving a secondary benefit, because of that, using the loader was essential.
I think you're right, it's not going to be worth it and you'll be disappointed. I started bagging my firewood in the spring with bags from the link below. My CK30 (1200lbs lift capacity) couldn't lift a full bag, I had to stop at about 80% and I certainly couldn't stack them. That was one big factor in trading up to my DK45 with 2700lbs lift cap., now I fill them full and stack them with no problem. The problem with the bags I use is they need to be full to retain their shape and not flop to one side.
I use these re-useable vented dumpy bags for my firewood - BAG Supplies Canada Ltd :: Vented Log Bags
On my B1750 - probably similar capabilities to your BX - I use the smaller size - 38x38x40" (97x97x100cm)
These are the guys I use. Amazing service, extremely nice guy. I'm using the vented bags that you fit into a frame over the pallet, fill it up, close the bag and remove the frame. I ordered bags in the afternoon and they arrived the next day. I'll order more as I need them, but can't say enough about the service I got.
   / Moving firewood palette with BX, bolt on forks #15
Do u have any pics of the steps u described (frame, etc)? I'm curious about the bags not holding shape if they aren't full. Does that mean as u remove firewood to burn, that the bag becomes unstable, and dangerous for kids or pets to be near?
I see the frame on the website. I would think I could just use the tractor forks to hold the bag loops in place, on a pallet. What am I not understanding? I do not see the need for the frame.
   / Moving firewood palette with BX, bolt on forks #16
I still say a larger pair of hydraulic cylinders is in order for the BX25 FEL.
I would have done it weeks ago but funds are not there. I have measured
and drawn the OE FEL Cylinder in CAD which will make the process much
easier I do believe. A 2.5" cylinder w/ a stock 1" shaft, if I remember right,
almost doubles the performance w/o even touching the pressure relief valve!
Yea yea yea, the sky is falling and I am going to bend my FEL. If I do I get
to fix it or buy a new one. End of story. I am of the belief a responsible
driver not doing silly stuff would benefit much.
I am not 100% sold on the 2.5" , 2.25" may be wiser.
   / Moving firewood palette with BX, bolt on forks #17
I still might build a set of forks, probably the chain on style, just for general use, moving logs, and taking the garbage to the highway on a pallet for garbage day.
I'll try and get a pic or two, I'm not sure were I stuck them right now. I start by putting a pallet on the ground. I then have a steel frame that I made up, looks like a gate, that I place around the pallet. I take a bag, put it on the inside of the frame and use spring clamps to hold the top of the bag to the top of the frame. Then I just start splitting and throwing the wood straight into the bag. Once it's full, I take off the spring clamps, pull the draw string and open one of the corners of the frame and remove it. I pick it up with the tractor (I'll guess it's about 1200 - 1500 lbs) and stack them. I do two side by side and one in the middle on top for a triangle shape. My stack is about 30' long and about 8' tall.
I've never unloaded one, this is a new thing for me. I don't think they'll be unstable and unsafe when they're alone on the ground. I don't love the first couple I have that I have others stacked on, but it shouldn't be an issue when I go to use them. I'm planning on building a dolly type skid so I can bring one over to the house, put it on the dolly and roll it to the corner of the deck and use it from there.
   / Moving firewood palette with BX, bolt on forks #18
That sounds like a great system. I look forward to the pics if u find them. Thank-you.
   / Moving firewood palette with BX, bolt on forks #20
niemeyjt said:
From the Apache site, this looks like it may be similar to Ken's
Fast Firewood B120 Firewood Bag - YouTube
J
Oh... That's very different from the frame I saw on the Canadian site u linked to. So these bags don't have the loops like the ones u bought...
Still a cool system. It's cool to have good options. Just makes it hard to pick one :)
International 656 Utility Loader Tractor (A59814)
International 656...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
Case 930 Tractor (A59814)
Case 930 Tractor...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2018 Deere 323E (A53317)
2018 Deere 323E...
