Thanks for all the advice.
no the starter is good, the ignition switch is bad so i jumped it directly at the starter.
I found some cheap tran/hydro fluid at tractor supply for $30 so i just put that in it. I just changed the fluid in my 2wd 2210 before this summer so I didnt want to mess with it.
Cleaning the screen and changing fluid got it back in service, goes into gear easy now.
Not sure if the 4wd it locking in or not? should I hear a click or how can I tell when its engaged, never owned a 4wd before. Going to drain and replace that gear oil tomorrow, is it just 90w?
All PTO gears seem to work, haven't hook anything up to test it yet though.
The 3 point still doesn't work, it does nothing at all, where do i start troubleshooting that? The valve under the seat it rusted so I can'T turn it, not sure if its open or closed, I sprayed pb blaster on it and hope I can break it free tomorrow.
All in all im pleased, I took my heat gun and got readings all over the engine and the hottest it got was 150 degrees, but I have not put a load on it yet.
here is a pic of the the screen, I had to use carb cleaner to break this crud loose.
