derating a trailer gvw in illinois
   / derating a trailer gvw in illinois #1
klog53
Nauvoo,Ill.
jd5520n, kubotal3800, yanmar
I own a 3-axle gooseneck trailer that I pull with my 3/4ton pickup. The combined gvw is 29,000lbs. Fully loaded I never gross more than 25,000lb. I make 2-3 trips to Mi.[avg.640 total miles] and several shorter into Ia. All told less than 3,000/year. I have a cdl/medical card/dot# but want to avoid IFTA requirements for being over 26,000lb gvw. Short of removing a axle, can i legally derate my 7000lb. axles to 5200lbs here in Illnois? Any help appreciated
   / derating a trailer gvw in illinois #2
Yes you can derate the GVWR of a trailer in IL. I derated a 14K trailer to 10K. If I remember correctly you can only change one or two weight classifications. You need to go to the Secretary of State office, pay a fee, and fill out a form. Do it when you tag expires or they'll hit you up for a half year tag too.
   / derating a trailer gvw in illinois #3
I could be wrong but, aside from air-brakes or commercial use, don't they go by actual weight of vehicle rather than gvwr for personal use vehicle? Therefore they would have to take you to a scale to be able to ticket you? Maybe call the secretary of state to be sure.
also, when I plated my trailer (4 or 5 years ago) they asked me which plates I wanted even though the title stated the gvwr. They said I could have gotten TA's for my 7k tandem axle! Most local LEO's aren't very well versed on a lot of these restrictions anyway (I actually explained briefly about the different trailer classes to my BIL county sheriff- he had no idea), but it sounds like you will be doing a lot of interstate driving and the state guys are the one's who do know this stuff.
   / derating a trailer gvw in illinois #4
You derate the GVWR not the GAWR. Removing an axle is optional.
The easiest way is to contact the trailer manufactuer. Your next best bet is a truck body builder or a local trailer dealer.
Don't confuse GVWR with GVW. ;)
   / derating a trailer gvw in illinois #5
Why? In IL just buy the plate for the weight you are going to haul. It that simple.
PM me if you have questions but no reason to change everything or reinspect you just have to pay for the new license plate, and keep the safety sticker current.
I have a 50,000lbs with 20k plates a 18k with 14k plates and had a tri axle gooseneck with 36k plates
just remember in IL you get ticketed if scale weight is more than plate rating or bridge formula or local ordinance which ever brings bigger fine.
   / derating a trailer gvw in illinois #6
He trying to dodge IFTA. Not license/registration fees.
   / derating a trailer gvw in illinois #7
You can't just buy the lower rated tag. You have to fill out a form to register it at the lower rating. It's very simple to do at the Sec. of State office. It's Illinois so of course there is a fee involved. In addition to getting around the regs he'll save a few bucks on his trailer tag.
   / derating a trailer gvw in illinois #8
It doesn't matter what you have on it for a license plate. If the GVW of the truck+the GVWR of the trailer is greater than 26,000 then you need a CDL and all of the big truck requirements. Even if the trailer is empty. OP is derating to avoid that.
The DOT is pulling over a triple axle and tandem dual trailers because it is almost certain that a CDL is required to have that combination.
   / derating a trailer gvw in illinois #10
That's why he has to fill out the form at the Sec of State office to change the GVWR of his trailer. It's no big deal. A few bucks and a few minutes is all it takes.
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
167 (A52708)
167 (A52708)
2004 AGCO Gleaner 3000 Corn Header (A56438)
2004 AGCO Gleaner...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
