MD83Z
Member
- Joined
- May 4, 2012
- Messages
- 27
- Location
- fallston,maryland
- Tractor
- 1958 JD 620,JD 410 backhoe,scotts L2548
#1 I would think that no oil would burn the pump and motor.....just a guess.
#2 inspect the pump and motor block surfaces for scoring....opposite end from spring loaded pistons.,...oil leaks past mating surface if too much scoring....
also could look at gear teeth ....Last...make sure flat spot on small gear shaft is positioned into case correctly on assembly.
#3 not sure "IDS"
#4 the adjuster allows for adjusting "creep"....if mower moves forward or reverse when supposed to be stopped.
#3 not sure "IDS"
