Are all post hole augers created equal?
   / Are all post hole augers created equal? #21
Just keep in mind that almost always when purchasing NEW IMPLEMENTS that you get what you pay for. Not saying that what you are looking at is good or bad. Everything has it's place and purpose.
Good luck ;)
You get what you pay for says a lot but you don't always get more just because you pay more. In many cases, you pay more because of the chain of events an attachment goes through before it reaches the end user. Usually, an attachment is produced by the manufacturer, then sold to a distributor, then to a dealer and finally sold to the end user. That food chain is something that can inflate the price and will not necessarily inflate the quality. Many of the high end name brands are now offering a lower end product, at a lower price, that is drastically lower in quality than their more expensive line so be careful there.
Our Everything Attachments post hole diggers, made in house, are offered to you by the manufacturer so the food chain is much shorter and the quality is high.
We offer five different models so we can provide a digger for any Category 1 or 2 tractor including subcompacts. We use a class 4 drive shaft on all of our post hole diggers which is a weak link on many other diggers on the market. Our augers also feature replaceable cutting teeth and tips.
If you do the research, I think you'll find that you will get more for your money with an EA post hole digger. To top it off, our diggers SHIP FREE TO YOUR HOME within 1,000 miles of Newton, NC.(except for the 7500 Cat2 that will ship free to a business or freight terminal) If you're outside 1,000 miles, shipping is generally very reasonable.
   / Are all post hole augers created equal? #22
Just so that we are all on the same page here, EA offers PTO driven PHDs from $700 - $1360. THEY ARE NOT OF EQUAL QUALITY. You get what you pay for. ;)
   / Are all post hole augers created equal? #23
I wasn't trying to degrade your point, only elaborate. We do offer products from other manufacturers but, like I said, if you do the research, you will get the best value with our post hole diggers.
   / Are all post hole augers created equal? #24
I use a Befco PHD, 9" auger , it's more expensive than TSC's, but it does 50 to 400 holes a year. In clay, and good ole top soil. Looking to make a down force cylinder for it. Dealer want's $450 to $500 for Befco's add on kit. I do like the idea of a hydralic auger but it's to pricey for me. Good luck in your choice.:thumbsup:
   / Are all post hole augers created equal? #25
I have a Shaver 3pt unit with a 12" and 24" auger. Have probably done about 800 holes with it for fence posts (using the 12") and 200 holes for trees (using the 24"), and it is still going strong despite having been put through every imaginable torture over the last 15 years!
I have very rocky soil here in central VA, and after years of having a helper or two hanging off the gear box via a tamping bar, I finally got a hydraulic down force kit last year. What a difference!
   / Are all post hole augers created equal? #27
To start with, I missed the Danuser J20-80 Tractor PTO Auger on your website. I am sorry about that, the price range should have read $700 - $1585.
So are you saying that the Everything Attachments 7500 Category 2 Heavy Duty Tractor Post Hole Digger for $915 is as good or better than the Danuser J20-80 Tractor PTO Auger for $1585? :confused3:
   / Are all post hole augers created equal? #28
I read your post and skipped the rest. i bought a OLD 3 point PH digger for 100.00, actually had to cut 3 trees to get it out. Ended up putting new driveshaft and bought a 9 and 12" auger for it. Last 3 yrs have drilled 3-400 holes with it. Just drilled 50 plus holes with it since the first of the yr. i am drilling in hard so. tx dirt, kind you drill till it bind up, kill the pto lift hit the pto, go back drill to you get deep enough, then go back pour in 5 gallons of water each hole , go back hit with PH digger it up and clean it out. Its no Danuser, its a cheapo. Dont be fooled into thinking you have to have the top of the line digger. they all work the same, I have sheared 5 bolts since I got mine, and thats in hard dirt
   / Are all post hole augers created equal? #29
Wow, dont really care whos feelings I step on, but thats alot of money for a PH digger.
   / Are all post hole augers created equal? #30
The quality is absolutely as good. The Danuser is rated to a 24" auger and offers an optional down force kit so it's not really an apples to apples comparison. We will offer a heavier post hole digger in the near future that will be rated up to a 24" auger. It will still be close to half the price.
I am not here trying to say that other products on the market are inferior or start any brand wars; I am here advertising our attachments and informing people of the value they provide.
Travis
   / Are all post hole augers created equal? #31
Travis
I understand that the Danuser is rated for a larger auger and has down force available. So it is a better unit, correct? Yes it costs more money, but by costing more money it has capabilities that the unit for less money does not have.
I am not implying that your implements are not good. But there are better. There may not even be anything that is better for the same price, :thumbsup: and you guys are starting to make some good implements & attachments. But that doesn't mean that there isn't anything that is better on the market. I guess that maybe instead of saying your products are the best, maybe it would sound better to say that you have the best product for the money. ;)
Just my :2cents: ,
   / Are all post hole augers created equal? #32
Curious about hydraulic models designed for skid steer QA when attached to a tractor.
2 things that come to mind are, 1 - as already mentioned - sufficient hyd flow and 2 - can you see where you are digging?
I don't think I could see the auger point from my tractor seat.
If I had a skid steer though, it would be a no-brainer.;)
Models for CUTs typically are rated for flows in the 6-15 GPM range, whereas a full-size skid steer auger will be rated for a higher range, say 10-20 or 20+ (depending on available flow for the SS). To my understanding, the auger torque is a function of the system relief pressure and the rpm is related to the flow rate. My DK45 is around 9.9 gpm, about right in the middle of the rated range for the Belltec NC-150 auger that I bought. The Belltec spec sheet (Rugged augers for farm & ranch applications. A planetary drive for a chain drive price. Belltec Industries, Inc.) suggests I should be turning around 64 rpm with 1180 lb-ft of torque (at 2500 system psi).
I found out right away that you can't see exactly the tip of the auger where it hits the ground (without standing up in the cab, anyway). Some manufacturers offer an offset mount for the auger that makes this easier; I've thought of getting one of those magnetic back-up/trailer-hitching cameras to stick to a lift arm and help me see where the auger is going and what it is doing.
Finally, as an aside, while I was researching augers, I stumbled across one (I've since forgotten which) that offered a cement mixer bucket attachment for the auger. I thought this was a pretty nifty idea; since my yard is filling up with single-use implements, it would be nice to have a hydraulic motor with multiple functions.
BOB
   / Are all post hole augers created equal? #33
That's exactly why I said this in my first post on this thread. Sorry if we seem confident about our products but we are passionate about what we do and are eager to let the world know.
   / Are all post hole augers created equal? #34
EA, I did not see any warrenty information on your website. Not just PHD, other tractor attachments. How is that handled?
   / Are all post hole augers created equal? #35
We have a link to our warranty policy on each web page for attachments made by us. Everything Attachments warrants all products manufactured by Everything Attachments for one year from the date of purchase.
   / Are all post hole augers created equal? #36
Just get the post hole digger that you like, and can afford. If it is the TSC or one of the EA units you will be happy and most likley get many years of service out of it no matter which one you buy. I for one have never had a problem with anything from TSP does this mean they have the best nope it doesn't, it means that I have never had a problem with them could I have had a problem with one from another MFG sure I could have but I probably wouldn't have. My point is most of the units will be fine you have done extensive research here and no one flat out hates the TSC unit that says something because if they were junk you would have seen that word more that once! :thumbsup:
   / Are all post hole augers created equal? #37
Some people don't want to waste productive time fooling around trying to force an underated machine into doing more than what it's designed too. That's also about the time when equipment gets broken and/or people injured.
   / Are all post hole augers created equal? #38
I have owned three standard type PTO post hole diggers. I paid a little more for each one as I bought along the way. The one I have now is a Bush Hog 2102. It is a standard PHD just like the two cheaper models that I owned previously. It was expensive. Was it worth the extra cost to me for durability and ease of use? For me it was.
   / Are all post hole augers created equal? #39
This might be a little late but many dealers were trying to get older inventory off their books by Jan 1 so they sold stuff cheap. I bought a brand new Bush Hog PHD with a 9 " auger for $500 from a Bush Hog dealer. After doing the research it looks like Bush Hog and Rhinos are exactly the same tool. I looked up both of the manuals for them and they are the same set of pictures and instructions, but for that price I took the deal. The only thing I feel bad about is that when I got to the dealer he had two PHDs and I ended up buying them both at $500 a piece. Sold the second one with the 9" auger on CL for $800 and mine ended up costing me just $200. I feel bad. I going to go dig some holes.
Tank Only (A59076)
Tank Only (A59076)
9000 (A47477)
9000 (A47477)
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
