Amco Offset Disc
   / Amco Offset Disc #11
Brian,
I agree to you using the word "fullest". I am a firm believer in having too much tractor and now,.... .........that 100 hp Mahindra is looking better and better! I'd even consider a used, different color tractor to have just for pulling. We'll see what the Big RED Beast can pull first hugs, Brandi
Brandi, It's not just the HP, you need some traction also. To handle your disk without problems, I would say 14-16k pounds with 100hp. The 100hp Mahindra ain't gonna cut it.
Honestly, as soon as I realized that the 100hp model was not a bigger 8560, I lost about all interest. :(
   / Amco Offset Disc
I undestand about the traction. What.........the 100hp model won't be bigger than a 8560, as in heavier also? That sucks. Oh well, I know where a New Holland Versatile is and soon it will be on the market. I am sure the owners will let me borrow it to try it out. They pull a 24 foot disc with it.
hugs, Brandi
   / Amco Offset Disc
A new Amco 8 foot 3 inch offset disc (F42 Heavy Duty) is $15,945 plus options.:eek: A new Amco 9 foot offset disc (F42 Heavy Duty) is $ 16,402.:eek::eek: I made out like a bandit.:D For the difference in new offset disc and what I paid............I can buy a good used pulling tractor.:cool:
hugs, Brandi
   / Amco Offset Disc
Brian,
Do you have any specs on the new 100hp Mahindra?
hugs, Brandi
   / Amco Offset Disc #15
Thanks Guys.
Flusher,
My concern was my 6520 pulling it, also. The guys that sold me my 6520........and that ran a Mahindra 7520 haying and discing, told me my 6520 would pull it and that if it got to hard pulling, to just raise it up with the transport wheels. I'm not too concerned. If my Mahindra is a little on the small side, I'll just buy a dedicated tractor for pulling and 3PH work, as I really like to keep the backhoe on the 6520. Mahindra has that 100 hp tractor out now. Maybe they will come out with a bigger Bradco backhoe to fit it. Also, my neighbor has 100 acres a stone's throw from my back gate and is working up a herd of Black Angus. He has no tractor and says he won't have to buy one now that he knows I am nearby and willing to work for him. This disc will fit into my business/retirement plan nicely.
hugs, Brandi
I bought a 13-ft wide Minneapolis Moline KS1300 tandem wheel disc (made by Krause) from Dave at DavesTractor (my Mahindra dealer) a few years ago. $600 including delivery by Dave and one of his guys. To handle it with my 5525, I cut it down to about 8-ft wide. Works fine in dry soil when I get the hayfield plowed in late September (after 3+ months of summer heat to bake out the soil). Like you, I use the transport wheels to adjust the depth.
Wheel disc delivery-1.JPGWheel disc delivery-2.JPGWheel disc mod-1 (1).JPGWheel disc mod-1 (2).JPGWheel disc-3.JPGWheel disc-4.JPG
Have fun with your new acquisition:thumbsup:
   / Amco Offset Disc
Flusher,
I have heard Krause products are very durable. How hard was it to cut down to 8 feet?
I plan on having fun with it. Thanks! I could have bid on a 12 foot Tuffline disc, but it had at least two gangs needing new bearing and maybe axle shafts and it was all rusted up. My Amco, you can spin all four gangs and the first gang is still spinning when I get around to spin the last gang.
hugs, Brandi
   / Amco Offset Disc #17
Flusher,
hugs, Brandi[/QUOTE]
Not very difficult job. Bought one of those Harbor Freight portable band saws and used Milwaukee blades. Cut through that square tubing like butter.
Portable Band Saw with Variable Speed
I shortened the axles and drilled a hole in the ends for a big cotter pins to hold the disc-spacer assemblies on the axles.
Use two of the scrap pieces of 4x4 inch tubing to fabricate supports for the transport wheels to move them more toward the centerline of the disc main frame.Welded the new wheel supports into place. I just left the old supports in place on the ends of the big axle that's part of the hydraulic lift assembly. This step was the most time-consuming part of this project.
Hope this helps.
   / Amco Offset Disc #18
Brian,
hugs, Brandi
I just look at the TYM specs. I know that they are not the same, but close enough to get an idea. I hope to see the actual tractor at the Tulare World AG Expo this week. :cool: I'll be sure to get pics if it's there. ;)
   / Amco Offset Disc
Flusher,
hugs, Brandi
View attachment 302436 View attachment 302438
Hope this helps.
I have seen these saws in action. They are slick. It could be harder to cut this disc down. It is all 1/2 inch thick angle that is 4x4. Of course, I don't wanna chop on it. I'd get a bigger tractor before putting a saw or gas ax to this heavy weight.
hugs, Brandi
   / Amco Offset Disc
Brian,
I have heard the Mahindra 100hp tractor will be better than the TYM. Hopefully it will be way heavier.
hugs, Brandi
2018 Freightliner M2 106 Cab and Chassis Truck (A55852)
2018 Freightliner...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
Informational Lot - Financing (A55315)
Informational Lot...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
