RedNeckRacin
Elite Member
- Joined
- Jan 6, 2008
- Messages
- 2,506
- Location
- Western PA
- Tractor
- John Deere 5083E MFWD, Kubota L3400 HST
So I have a question that I'm not sure where it fits into but this was my best guess.
Backstory: Anyways, I have a shallow layer of topsoil then clay then increasingly harder shale the deeper you go. I have a building on a level pad that was cut into the hillside. I can put water lines and a drainage line in deep enough until about the middle of the pad where I run into the shale at depth. This has not been a big problem and I usually just worked around it. SO the problem comes into play with the possibility of putting a "lean-to" on the upslope side for convenient hay storage. (Yes the out slope would be easier but there are other plans for it. The contractor who installed the building had a heck of a time drilling the holes for the posts.
I was interested in tackling a project and gaining some more space for the addition. I know I basically have three options. My granddad owns a 480C back hoe which I pretty much have unlimited use of as long as I fix it when it breaks (which happens somewhat regularly due to age.) I can rent a small bobcat (about a 331) that will dig circles around the older case but I have to pay to rent it. Or I can contract it out( hopefully this is a last resort but remains a viable option) but the least desirable at this time.
My first thought was to build/buy a ripper (frost tooth) to replace the bucket on either machine and have at it. There are some cheaper used buckets on the classifieds and eBay that I could use the mounting flange and add on from there. The rental place has no problem with changing attachments as long as it was made for that machine.
My next thought was why bother with all that fabrication when they already make rock teeth for both machine's buckets and relatively cheaply compared to fabricating/buying a specialty tool.
I guess my question would be, is it worth buying the rock teeth for the case or the bobcat, or should I just get down to fabricating something for my needs?
Note: I have tried the narrowest buckets on both machines already and it´s almost a fruitless process to make any advances. It´s also not feasible to run anything up and down the slope due to the proximity of the building to the toe of the slope. SO I basically have access to three sides of it. The other thing is that the building is 100' long and I would like to blend the current slope into the proposed one.
Anybody have any good ideas? Searching hasn't provided much help either.
