House for my Parents
/ House for my Parents #541
Nice job on the cabinets, the sink base is very neat, so many times the installer will butcher the openings for the plumbing.
Dave
/ House for my Parents #543
Being from an area and growig up in an older home and all homes of friends were on a crawl, i just cant get use to houses on a slab.
You have to destroy your home to fix a plumbing issue with a drain or supply if you put them in the floor for a reason like to get to the island, unless you laid a chase pipe in the context of your water line and you can pull pex through if needed in future.
I know a new home should not need work for 20-30 years but things happen. And most of us dont worry about such as that but i guess i do worry about this stuff. Also its not as easy to pull electrical or phone or plumbing as you just cant crawl under it.
What would be the cost difference in your case to put a home on a crawl?
/ House for my Parents #544
Almost all homes in this area are built on concrete slab and it's actually pretty seldom that there's a problem, but it does happen. An aunt and uncle of mine had a water leak under their house in Dallas quite a few years ago and the plumber just cut the incoming line just outside the house, ran the water line up into the attic and then down where needed. I don't know what that cost, but I'm sure it wasn't cheap. And I once looked at a house that had a big jack hammered hole in the slab in the living room to fix such a problem. The other, more frequent problem, is settling and requiring re-leveling by digging under, using hydraulic jacks to raise part of the foundation, then pumping in concrete, leaving the jacks in place. That's not cheap either.
When my brothers and I were building a house for one brother, they had built homes in Alaska, so we dug out for a 4' crawl space under the house and when the concrete truck showed up to pour the footers, the driver looked at the forms and asked, "Where ya'll from?":laughing: He said, "I knew you weren't from around here to build something like that."
I like that wall for island, Eddie! Is that blue pipe that new fangled PEX?
Yes, I ran PEX for all of the runs, and then went to copper for all of the connections. The advantage to PEX is that you don't have any joints, or connections on your runs. Leaks almost always happen where you connect the pipes. The part I don't like about PEX are the plastic fittings. They might be fine, but for peace of mind over time, I wanted something with a proven history.
Eddie
I grew up with pier and beam foundation homes and used to enjoy playing under them as a kid back in CA, but here in TX, they are very rare and from what I've seen, only in the oldest of homes. Each has it's advantages, but overall, I prefer a slab over pier and beam. With all our humidity, bugs and critters, it's nice not to have anything under there. The pier and beam homes are the ones with the most foundation issues. While I'm sure most of that is because of age, materials used and a lack of knowledge about soils back then, it's just a lot easier to build a slab then to design and build a pier and beam foundation that wont move with clay soils.
You are right about the pipes breaking. I just finished a job where all the copper water lines where run under the house with flexible copper. The break is under their master bathroom vanity on a water line going to their tub and shower. I could have either tore out the vanity and gone through the concrete to find it and fix it, or I could cap that line and run a new PEX line up the wall, through the attic and down another wall. I ran the new line, which just took a day.
I have another client who had a water leak under their slab and they hired a local plumber to find and fix it. They went through the slab in four places. I'm not clear why because I'm getting the story from the home owners, but now that the plumbing part is fixed, I'm going to repair the slab and redo their floors.
If either of those homes had been on Pier and Beam, this would have been a lot easier and cheaper for them to fix. Of the tens of thousands of houses in Tyler built like this, it's still pretty rare to happen. Going with PEX under the slab on my parents house for the water lines to the kitchen island could lead to something like that happening. I'm hoping the PEX is the right product to use.
Eddie
We've been doing a lot of things on the house, but mostly it's slow going. We went shopping for granite Saturday, which was fun. They also bought all their appliances, which should be delivered in a week or so. We want the appliances in place before the granite, so they can get a perfect fit.
Floor tile is all in. My mom is doing all the grout work. She has a talent for it and is very proud of how nice it's looking. I'm done with the master bath shower walls, but still need to do the floor. I also have to do the common bathroom tub/shower tile work. We should be on interior trim pretty soon.
IMG_20130629_093851_590.jpg IMG_20130630_120455_338.jpg IMG_20130630_143150_756 (1).jpg
Eddie
/ House for my Parents #549
Very nice Eddie. I am sure your parents will appreciate. As an aside I hope you are providing your mother with knee pads and a glove. That is a lot of grouting.
/ House for my Parents #550
Eddie
I've always used brass fittings for pex. I mainly use Watts brand pex.
/ House for my Parents #551
Very nice, Eddie
David Sent from my iPad using TractorByNet
/ House for my Parents #553
Ditto here....all PEX, no plastic anywhere in my house.
Eddie...looks great, keep 'em coming!
Two points.
1. The PEX itself is plastic, so you have lots of plastic in your whole plumbing system.
2. Early on, PEX had failures because they made the brass connectors from the wrong kind of brass, and there was serious corrosion. I go out of my way to use the plastic connectors because of this issue...
/ House for my Parents #554
Two points.
We've been working on trim now that the tile is done. I show my dad how by doing some over the weekend, and then he finishes it up during the week. Mom fills the holes, caulks and paints. They are a good team and we are making great progress because of how hard they work.
The insulation is Attic Cat blown in 24 inches thick for an R-60 rating. I was in the attic for over six hours. The last hour is when it got warm, but there wasn't any way that I was going to quit until I had it all done.
The closets are all pretty much the same. Shelving units that I built are in the middle and clothes rods on either side. To me, this seems to be the best way to get the most out of a closet.
All the appliances have been delivered and installed. They went with Samsung on everything from Lowes, where they got a pretty good deal.
We are still waiting on the granite. It's been cut and we are scheduled for installation this Thursday.
Eddie
/ House for my Parents #556
put the washer and dryer on stands
Laundry room isn't done. I'm going to build a flat counter/table over the machines for folding everything on. They thought about stands for storage, but didn't want to bend over to get anything out of there, and my Mom didn't want to height of the top of the machines any taller. I will also build a cabinet with doors to go across the back wall and some sort of hanging clothes rod on the left wall. We are still working out the details, but since it's functional, it's sort of a low priority right now.
Eddie
/ House for my Parents #558
Eddie
Eddie, the good son, and his Mom & Dad....it doesn't get better than you all doing this together....Just a thought Eddie...When I built our house I surprise my wife with a Chandelier in the laundry room...I was in Loews one day toward the end of our build and we had not decided on lighting in the laundry room...I saw a really neat chandelier on sale and bought it and surprised her....She gets more comments on having a Chandelier in her laundry room...Just a thought...it gives plenty of light....you could surprise your mom...
You have done a great job....you should be really happy ...so if you're not then you should be....:thumbsup:;)
/ House for my Parents #560
Eddie
Eddie, I don't recall, did you do any type of radiant barrier?
2017 John Deere 825i XUV Gas Utility Cart (A59228)
2017 John Deere...
UNUSED MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED MINI...
Informational Lot - Shipping (A61307)
Informational Lot...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(125) PALLET OF UNUSED SAFETY CONES (A60432)
(125) PALLET OF...
