Could This Be The Best Lawn Aerator Ever??
   / Could This Be The Best Lawn Aerator Ever?? #41
I'd go with the 36" 3PH model on a X749.
48" across is perfect but I don't want to mount it to a 3pt. I don't want to buy 1k dollar 3pt just to use this once a year. I have my larger tractor for the 3pt work but in most yards a large tractor does more damage than good. I was thinking of making my own if i just knew where a guy could buy the weighted disks with the hollow tines. I am planning on routing a set of hydraulic hoses under my 749 to make a rear remote for just these kind of things. The ryan model pictured is the one I want to emulate.
   / Could This Be The Best Lawn Aerator Ever?? #42
I thought all 749's had a 3PH, that was why I suggested that.
   / Could This Be The Best Lawn Aerator Ever?? #43
Nope just an option.
EA, any chance you will make a pull version with hydraulically operated wheels to lift the tines out of the ground? I don't like to run my big tractor across the lawn and think my X749 and a pull behind would be the ticket.
We have no plans for a pull type as of now.
   / Could This Be The Best Lawn Aerator Ever?? #45
I need a good aerator and agree that the 36" behind an x749 is a good way to go. I use the 3ph on my x749 frequently for lawn maintenance and try to keep my 110 and 4520 off of the lawn as much as possible. I use a pine straw rake for cleanup 72" very frequently and is one of the reasons I bought the little machine.
Be sure to get your orders in early for spring. If you want the best Aerator/Core Plugger on the market, ours are second to none!!
Our Xtreme Duty Aerators are now available in 36", 48" and 60" wide models with regular or alternating depth spoons weighing up to 1140 pounds! :shocked:
Here's a look at the alternating depth model:
Travis
And another video of our alternating depth model!
   / Could This Be The Best Lawn Aerator Ever?? #48
What is the width of the 36" version from outside spoon to outside spoon? Also overall dimensions?
I am trying to decide between thehttp://www.everythingattachments.com/Lawn-Aerators-p/ea-xd-la-36.htm and your drum style 48" Everything Attachments Tractor 3 point hitch Core Plugger, Lawn Aerator
What are the advantages of the gang style over the drum?
This will be used on a Deere 1025r that has a lift capacity of 680 lbs 24",behind the link ends.
   / Could This Be The Best Lawn Aerator Ever?? #49
The one with the independent wheels will allow you to make turns. The drum style will require weight to be added to the top which will raise your center of gravity. The one with the independent wheels will has the weight built in and will keep the center of gravity lower than the other style. I have had an core aerator for over a year now and i think it has helped my yard tremendously. They also help smooth your yard. If I was going to buy an aerator for a SCUT it would be this one. Xtreme Duty Lawn Aerator With Hollow Coring Tines
The width is approx. 31" from outside of spoon to outside of spoon.
Overall dimensions is 44" W x 36" D x 36" H
Roger gave a good explanation of gang style vs. drum. Our drum style is heavier than most because they have heavy frames and they're filled with sand at the factory.
We use the high quality, US made galvanized spoons on both styles.
Thanks for the inquiry.
Travis
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
208315 (A58376)
208315 (A58376)
2006 Acura RL Sedan (A59231)
2006 Acura RL...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
