Mx5100HST OR DK50HST OR 5035 MAHINDRA?
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA?
I have some descent dealers around.
My L3200 has industrial tires.
Today, I am leaning towards the MX5100 because it has 42.5 pto, and the kioti only has 37.5, so that's another 5hp on the pto.
I'm ready to just flip a coin and just buy one. I'm tired of thinking about it.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #32
FYI, the Mahindra 5035 also has 42.5 pto HP.
What do you plan on using anyhow that will require the extra 5 PTO HP ? I ask because my buddies L3540 has about 10 less PTO HP than my LS (28hp vs 38hp) but we pretty much use the same implements anyhow and his handles them just fine. Most PTO implements are 6 ft or less, 38.5 HP will handle them just as well as 42.5 will. My buddy pulls his 84" finish mower with his and handles it nicely.
I'm not challenging your choice, I don't think you can go wrong with any of those 3 tractors... I'm just thinking that basing your decision off +/- 5 PTO HP might not be the best factor, unless you truly need that additional 5 PTO HP to run something larger.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #33
Also implements over 6' get expensive.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #34
I exhaust my PTO power way more often than I lose traction and you just can't add HP like you can with ballast to get more weight. You can always add weight on your 3 pt if you need it but you are stuck with the HP you get the day you buy it. Unless you are into risky engine mods.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #35
I exhaust my PTO power way more often than I lose traction ....
Really? Doing what, and with what tractor, implement, implement size & tractor HP? I have never once run out of PTO power... sheared plenty of shear pins, broke a PTO shaft... nearly buried an auger with my previous CK20 because I shot the auger down too fast but almost didn't have the 3pt lift strength to get it back up.
If you're running out of PTO power that often, I would surmise that you're either over-sizing your implements, or you haven't learned how to handle them properly.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #36
I will not respond to aggressive posts.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #37
It's not aggressive Tom... I'm asking because I'd like to know how you manage to max out your pto more than you lose traction. Please explain.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #38
I saw a picture of Tom's once, he lives on some fairly flat ground. Traction likely isn't much concern for him.
That being said, any machine can bog the PTO going through tall wet grasses too fast, but that's not so much a lack of power as it is the physics of being able to exhaust X amount of grass-weight with the given surface area of blades measuring Y at a rate slower than Z speed is taking in new grass to cut. Blades with more surface area or more blades is more rotating mass and should require more PTO power to spin, but blades with more surface area or more blades would move more grass out of the deck faster and therefore create less PTO-bog in the same situations at the same speeds. But this is still a physics issue able to be overcome by slowing down or adding more blade surface area. Adding power in such a situation just creates additional wear on components or requires larger components better suited for X, Y, and Z.
I agree it is difficult to need more PTO without needing more tractor overall... Many implements I've checked into that had "horsepower requirements" were mainly to ensure you have heavy enough tractor to handle the implement.
For the same or similar money I can see wanting the extra 5 PTO horsepower when all else is equal, but if it meant paying much extra or going with something else of lesser spec, I could live with 5 less. I don't think you can go wrong with any of them.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #39
Tell me about it...I'm looking at a 7' brush cutter, 7' scrape blade, and 7' rake to replace my 6-footers. The brush cutter would be a convenience, but the other two I'm just not happy with the smaller size, especially if you angle them.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #40
agreed...
Gman... check this out. It's the same blade I just picked up (can't believe there's 2 around here, I have half a mind to pick it up as a reserve!!! ). Blade works awesome. 8ft Heavy Duty 3pt Blade
2013 Ford Escape (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
New/Unused LandHero Pallet of Binders/Chains (A51573)
New/Unused...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
1271 (A50490)
1271 (A50490)
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
