IH 300 Utility....My new project
/ IH 300 Utility....My new project
Here is a update panorama shot of the shop. Can you spot the tractor?:laughing:
So far here is what I need
Engine tune up kit....................................$50
Ignition switch..........................................$20
Choke cable..............................................$15
Tach cable.................................................$15
Gauge cluster.............................................$70
All tie-rods.................................................$100
Center ball stud/pivot..................................$50
Lots of seals...............................................$150
Misc TA components...................................$200
TA clutch components...............................$200
Clutch and throwout bearing.........................$150
A few other odds and ends..........................$200
Paint and supplies.......................................$100
Puts me just shy of 2k with the purchase price. I think (hope) it will be worth 2x's that or close to it once restored and done right.
There are a ton of other odds and ends to fix, like broken/striped fastners, etc. But mechanically, everything was great. All the bearings feel great, and all of the gears look great.
/ IH 300 Utility....My new project #22
sounds about right. I almost always figure 2x purchase price on a runner to refurb.. and 4x+/- on a non runner.
Now I just got to source some TA components.
One junkyard around here I was hopefull aout wants way too much for a used TA. They want $500 for the TA and TA clutch. A referb TA is ~$500, but I'd jsut rebuild myself for ~$200. And the clutch components are ~$200 for what I need. So I cant see spending more than buying new and having a rebuilt TA.
And all for a tractor sitting in a boneyard that they probably paid $500 for total....:mur:
I wish that guy that has lots of parts on ebay would call.
/ IH 300 Utility....My new project #24
For some items that are hard to find, I post a "want to buy" ad on TractorHouse. Salvage yards call you, and give the price. There can be quite a difference in prices, but you also have to keep in mind the shipping costs. I have also had yards drop their price to make the sale, when I told them I found one for less money. I wasn't BS-ing them either... Told them to call and check... Best to wait 36 hrs or so for all to respond.
http://www.tractorhouse.com/Default.aspx
For seals & bearings, if you can't find the number on either, you can cross it through NAPA's online site. You can check Messicks for dealer price on them, then check NAPA's price. NAPA AUTO PARTS
Most definitely run the part number from NAPA (actual bearing or seal part number) on JBR's site. They deal in NOS bearings & seals, and most run 40-50% less than NAPA, Bearings Inc., etc. Usually took a week to get them shipped, but it was worth the wait to me. Everything I got a couple years ago was Timken U.S.A. & CR seals.
JBR 17 LLC,
Well, got all the seals and stuff I need ordered.
Two brake rod seals, two brake housing seals, Two TA case seals, Trans input shaft carrier seal, one outboard wheel seal, two brake housing o-rings, and input shaft carrier o-ring.
Total damage was $84 delivered:thumbsup: from various sources on ebay. All good stuff. SKF/CR or National/timken stuff.
Napa wanted over $150 for the same stuff not counting the o-rings.
I also managed to source a TA. Complete everything. Clutch components, and even the shift fork that I need. Came out of a working and operating tractor that was converted to a pulling tractor and a TA delete kit installed. Guy is out of kentucky and a truck driver and running a load up near me tuesday. So I will meet up with him and take it off his hands for $150:thumbsup:
All I will need to complete the TA then is the throwout bearing, and maybe a clutch disk depending on how it looks. I will also take a look at the ramps and rollers for the O/R clutch.
/ IH 300 Utility....My new project #26
Gotta' love the internet for finding stuff..!!
Absolutely.
Good timing too. He had it listed on ebay for $125 bid style and $69 to ship, and only 22hrs left and no takers. I sent him my phone #. He called me because I wanted to ask him about the shift fork too. Mine was seized on the shaft, and no amount of heat and pounding was bringing it off. After seeing that they were ~20 bucks on ebay, I used a zip disc and sliced it off. HE had one of those and is bringing it with him.
The parts list still left to order is getting smaller, and it looks like I am going to stay under my $2k budget including purchase price:thumbsup:
Heres a few update shots
Still waiting on a few seals so I can install the input shaft, and main throwout bearing, then I can marry the engine back up.
Seals are due on monday. So I guess that gives me 3 days to get the engine ready. Need to replace the rear main seal, then a good cleaning, then paint.Once all of that is done, its just down to sheet metal and small bolt on parts:thumbsup: Might have her done before Christmas, even though this was supposed to be my winter project:laughing:
/ IH 300 Utility....My new project #30
looking good and iron like that is hard to find these days
Thanks.
Still need to source two more parts and I'm set (I think).
Still need the shifter top cover, as mine is broken, but may end up just welding it. And also need to find the small 4-bolt cover that goes over the TA clutch. May try a few more junkyards and see if they will sell for a decent price. But nothing on ebay or online that I have found.
/ IH 300 Utility....My new project #32
try postig on ytmag / IH forum. lots of red iron mongers there.
Well I welded the shifter cover. It turned out good so I don't need one of those anymore. And will probably just make the ta cover.
Got all of the accessories off the engine today as well as the pan and rear main seal. Also sand blasted lots of other parts. Tomorrow is gonna be a lot of cleaning but hope to shoot some more primer tomorrow when I get the engine prepped and the rear main/pan back together.
/ IH 300 Utility....My new project #35
good deal. i made a delete cover on a c for the belt pulley before. not super elegant. but works!
Yea, gonna be a tad tricky. It would be nice if it was just a flat plate with some holes. But it has a raised part to clear the TA clutch:mur: We'll see what I can come up with.
/ IH 300 Utility....My new project #37
flat plate with relief cut, then weld a section of pipe to that. with a cap or cap welded on maybee
Yea, that may be a good Idea.
Also considering a piece of channel Iron doing the same thing. I guess it will just be whatever I have that fits the best.
Here is how the shifter turned out:
/ IH 300 Utility....My new project #39
Good Afternoon LD1,
Nice project, enjoyed the read, and that will be one heck of a good tractor when done. Like someone said earlier, great little bush hoggin machine...
I have had pretty good luck on the ytmag/IH forum lookin for odds and ends myself...
Waitin on more pics... ;):)
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
Adams Tilt Trailer (A61307)
Adams Tilt Trailer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
iDrive TDS-2010H...
CAT 930M (A58214)
CAT 930M (A58214)
