GManBart
Elite Member
- Joined
- Dec 10, 2012
- Messages
- 4,976
- Location
- Detroit, Michigan
- Tractor
- Massey Ferguson 241, Kubota SVL90-2
I am going to either put a barrel stove in it or putting a gas wall heater in. Initially, I will probably just go with a kerosene heater to knock the chill off.
You may want to consider insulating under the slab to keep it from acting like a heat sink. I went with 2" thick R10 sheets under my slab, because of the radiant heat (no sense heating the dirt). Home Depot sells them for a bit under $30 per 4x8 sheet, and Lowes is a touch higher.
I'm in the middle of building a 40x64 barn that has a continuous poured foundation, but will be like a pole barn from the foundation upwards. We've already poured the 24x40' shop side slab, and will do the 40x40 barn side in the Spring (trying to get the walls, doors, and roof up before the weather gets bad).
My general advice would be to plan for everything taking twice as long as you expect it! Also, a visit with the local building inspector is a good idea before you get too set on any particular details, or plans. I had some additional challenges, because we were demolishing a house where the barn is going up, but I can't describe how many times I had to call/visit the building inspector to get things lined up for the permits. I would just make sure they know you're doing the project yourself, haven't done one before, and ask that they give you detailed guidance on what they need to see, and the order of events. There's nothing worse than being ready to do something, only to find out a different inspector has to check it before you can proceed. For example, we put radiant heat in our slab, and I had to get the mechanical inspector to check it, even though the plumbing inspector had already signed off on his part. You'd think the plumbing inspector could inspect radiant heat tubes (plumbing), but that's not how it works here.
Anyway, that's a long way of saying to try getting as much guidance as possible from the building inspector in the hopes it will save you some time, and headaches!
Inspirational photos....the first was after we poured the shop side slab (you'll note the PVC for the bathroom...full shower, toilet, sink)...man cave alert. The second is after putting the header beam up over the two 18'x12' overhead doors.
