Would like honest suggestions about tow vehicle issues
   / Would like honest suggestions about tow vehicle issues #251
I like the way one of the diesel mags "recycled" a pppprrrrriii, ran over it with a tank. :)
I am so fed up with this government forcing our hands in soooo much of our lives.
Now back on topic, what major flaws should I look out for on a 00-03 (early 7.3 model) Ford? Am seeing some of those at very
you need 06 chev 1500
   / Would like honest suggestions about tow vehicle issues #252
Hey now we (as in non-ford lovers) make no claim to him. :laughing:
All of his statements include "we" when referring to different vehicles/tractors he says he has. This to me indicates that he doesn't actually own any of them... probably Daddy of Grandpa or Uncle Cletus I would have to assume.
No when I mean family owns them on hour farm
I own a 2000 F250 w/automatic and 3.73 gear ratio and I would say to look for leaks in the valley of the engine which will show up at transmission bell housing area like a rear main seal leaking, also leaks at oil cooler on drivers side of motor under exhaust manifold area. The transmissions are a weak point but if you beef it up and use a triple disk converter you will be in good shape. Also recommend trans.temp gauge and a 6.0 cooler if you tow a lot. Mine has been a very good reliable truck that I tow 10,000-12,000 lbs with almost every day in FL. heat. Also check the injectors as they are a costly repair usually around 200,000 or slightly more, depending on individual truck. Overall I am very happy with the 7.3 it is a awesome motor for longevity.
John
For the ignorance in me, explain "check the injectors". How and what for?
I was all set to start looking for an 06 Dmax but these trucks are showing up under 20K with right around 100K on the clock. If one does have oil leaks are they costly to repair. or have repaired?
Wow good reading. Thanks for the link. I have a LOT to learn about how diesels work.
For the oil leak/cork, I assume you mean cork gasket?
   / Would like honest suggestions about tow vehicle issues #258
For the ignorance in me, explain "check the injectors". How and what for? I was all set to start looking for an 06 Dmax but these trucks are showing up under 20K with right around 100K on the clock. If one does have oil leaks are they costly to repair. or have repaired?
It is my understanding that on the 7.3L, the motor has to be pulled if the oil pan has to come off for any reason (rusts through/gasket replacement etc.).
   / Would like honest suggestions about tow vehicle issues #259
You are right on that but that is only a problem on northern trucks, something that I don't experience. we remain rust free for the most part except closer to the ocean.
John
Rust isn't usually an issue here either, but 30 min west the ocean air can cause some issues.
Looking online I see injectors are about $150 each so at $1250 a set, isn't cheap, but better than newer versions, like the '06 Duramax at more than twice that amount. Yikes!
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
