Texas Grapple Shootout
   / Texas Grapple Shootout #41
It appears that as long as there is no cross bar, in front of the crossover point of the lid, sticking brush would fall out easy or could be dislodged by back dragging.
Xfaxman, I like the way each of you tines has a matching lid tine.
A grapple like yours, about 50-54" with the tines 6-7" apart, a full lid with matching tines, and opening at least 45" or more - that would be my ideal grapple.
Sounds like your about ready to give blueriver a call. He does good work.
   / Texas Grapple Shootout #42
I have wondered whether the serrated tips on the lower tines of the EA Wicked Root Grapple would cause roots and small branches to be hard to dislodge from the grapple.
I can see how Xfaxman's doesn't have that problem. I sure wish I could find a lighter version of his grapple. It looks almost perfect, but is way too heavy for most CUTs. If I remember correctly, I think his tines are 1" thick. :eek:
Blueriver makes custom grapples? Tell me more, you got my attention.
   / Texas Grapple Shootout #44
I don't know if he does or not but you might discuss it with him.
He has a thread showing his construction of the multiple bale hay collectors he sells.
   / Texas Grapple Shootout #45
Yep, 1" thick and the frame that is tubing on most grapples, is solid bar on this one.
44" wide, weighs 946 pounds.
6 Tine Gorilla Grapple - attachments for skid steer loaders, small compact construction equipment - Sidney Manufacturing
Here is a guy that will build what ever you want.
LC.Root_Rake_Grapple_Tractor_Attachment.IMG_20120601_083326-405x300 (Medium).jpg
www.TheRakeShop.com / Root Rakes Grapples Attachments & Skid Steers
   / Texas Grapple Shootout #46
Thanks for the comparison. I think if I had it to do over again, I would go with the rake type. I have the bucket style and it's somewhat difficult to pick stuff up, especially bigger logs because the front of the tines are upturned and it has to be tilted so far forward. Very difficult to pick up multiple logs.
Of course, if I had the rake style, I would probably find problems with it too.
   / Texas Grapple Shootout #47
IMHO tooth design has more impact on digging ability than any other aspect. I went with a wider spade style with lots of horizontal "cutting edges" because most of the roots in my neck of the woods grow up and down.
I can sink the teeth up to the cross bar and dig up to 10 to 12" deep, but seems to work best 4-8" down with the cutting edges more perpendicular to the roots. In my wet clay soil if you're not careful you can move a lot of dirt! Dirt does build up on the spade style teeth and requires quite a bit of "grunt" to run effectively but it does a great job. Here's a picture of the grapple and one showing how the dirt builds up on the crossbar.
It is a dual lid rake style and this is what it looked like new.
A single "lid" was why I shied away from a root rake style grapple and went with the bucket style. I wanted two independent arms. I like yours. What make is it? Do you have a link?
hugs , Brandi
   / Texas Grapple Shootout #48
That would be a construction grapple, not designed for digging anything. I have heard of folks using fork lift forks on a FEL to pop out roots. Guess that's why I have heard of bent and broken forks too. The right tool for the right job saves wear and tear on tools and equipment.
hugs, Brandi
I have never heard of digging hay? ( the first main use described by the post i answered) but did say I didn't know how it would work for Yapons i have picked up 1000lbs. + round bales with my tined grapple and trees and stumps, and it is very effective at going thru and picking up debri or slash piles (Logging) We also have a tie-barred grapple with slightly longer lower tines Some what similar to the one Deerherd posted on the families Bobcat S series tracked skid steer and yes it would be better for ground clean up behind a dozer
There is one more advantage to most round tine grapples -If a tine should get (bent or broken) you simply remove a bolt and replace the tine, although I guess I haven't worked mine hard enough yet to require replacement... :D
like most have said any grapple- is better than no grapple.
I hope all that are searching for a new grapple get the one that does everything they need it to do...
   / Texas Grapple Shootout #49
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A54865)
Vermeer D16X20A...
Hyster H225E (A47384)
Giyi Pallet Forks (A53316)
Giyi Pallet Forks...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2010 INTERNATIONAL DURASTAR 4300 CHEMICAL TRUCK (A55745)
2010 INTERNATIONAL...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
