Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #311
All trucks with good options cost a lot..
   / Ram1500 EcoDiesel V6 revealed! #312
Last I checked (a while ago, admittedly), this Ram diesel will be offered in a base truck in Canada.
After ordering, you might have to wait months to get it, but I'm hoping that is still the case.
Rgds, D.
   / Ram1500 EcoDiesel V6 revealed! #313
Exactly! Who would have thought you would find all of these creature comforts in a pickup!
Personally, I think all of the "Big 3" make good pickups, and Ram has come the furthest in the last 5 years.
   / Ram1500 EcoDiesel V6 revealed! #314
There are people arguing over a few hundred pounds of weight or tow rating. This truck is a light duty truck, most people use them like a car. These numbers don't mean a thing to the average buyer.
   / Ram1500 EcoDiesel V6 revealed! #315
Have you ever been in a campground? Lots of folks tow with half ton trucks. I was one until I upsized my trailer to a fifth wheel.
   / Ram1500 EcoDiesel V6 revealed! #316
This is true.
How many empty, unused pickups do you see in a run of a day? Lots here. Most of these vehicles, particularly the fully loaded ones, will be mall cruisers.
   / Ram1500 EcoDiesel V6 revealed! #318
GVWR sticker. What jumps out at you about this one, in comparison to your Ford.
Payload Sticker
My sticker was 1835 lbs minus your sticker of 1256 lbs equals 579 lbs or 47% more capacity.
I didn't opt for the Max payload which would have added an additional 500-600 lbs to my 1835 making it 2335-2435 lb payload.
You mentioned your tow rating was 7900 lbs. If you consider the tongue weight to be 12% or 948 lbs, that only leaves you 308 lbs for passengers and belongings.
Point being the published values from the manufacturer is for best case scenerio with no options. Your truck was 254 pounds different which is substantial.
Now I really like the Ram trucks but it wouldn't work with my 940 lb tongue trailer I had at time of purchase. You are enjoying a better ride quality than I have in return.
   / Ram1500 EcoDiesel V6 revealed! #319
32% less
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2022 Weber MT CF2A Plate Compactor (A55851)
2022 Weber MT CF2A...
Plastic Buck Statue (A55853)
Plastic Buck...
