k0ua
Epic Contributor
Hi.I appreciate all the effort you are putting into this.Yes,I do have the skinny pedal and NOT the one similar to the Grand series.The problem I have is lifting my right leg as well as lifting my foot.I can no longer put my foot under the pedal and lever it up to activate reverse.I have tried resting my foot on top of the pedal and tried rocking it back and forth.This is probably the easiest method for me but not ideal since I am 6 foot tall and my right leg ends up being in an uncomfortably high position.Maybe if the seat was 2 to 4 inches higher?
Raising the seat might help, but I wonder how everything else (steering wheel and loader control?) would work out with that idea. Maybe make up the add on lever and see if that works for you. You might find that letting go of the loader control could work for you by positioning the loader lift up and rolled back a bit, then move in reverse.. Maybe not ideal, but you might could live with the compromise. You might just have to try different things and see what works.
