How Do You Keep A Draw Bar From Spinning?
   / How Do You Keep A Draw Bar From Spinning? #21
This is my homemade multiple use draw bar, receiver hitch, short skidding boom pole, ballast weight bracket, middle buster, sub soil, yet to be invented tool tow bar...
Good luck..
   / How Do You Keep A Draw Bar From Spinning? #23
   / How Do You Keep A Draw Bar From Spinning? #24
   / How Do You Keep A Draw Bar From Spinning? #26
   / How Do You Keep A Draw Bar From Spinning? #27
That would do fine as far as keeping the drawbar from rotating but I am not sure how it would do as a receiver hitch. I prefer a solid square tube.
I think it would be adequate for moving most empty trailer's or some light loads.
   / How Do You Keep A Draw Bar From Spinning? #28
   / How Do You Keep A Draw Bar From Spinning? #29
This is how it was done on the old Ferguson tractors. The old farm trailer my dad towed around with one of these was simply a clevis type hitch. One tongue of the clevis went above the drawbar and the other tongue was below the drawbar. The trailer was attached with a pin that passed through the trailer clevis and the drawbar. You didn't need to stop the drawbar from spinning with this type of arrangement.
   / How Do You Keep A Draw Bar From Spinning? #30
Worked because of the hardware on the lower links.
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
Champion Vibratory Roller (A60462)
Champion Vibratory...
204549 (A52707)
204549 (A52707)
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
